Frigidaire front load washer making a noise and jumping when going through the spin cycle. Why???
    Sniper:
  • 88 Answers
If this is a brand new washer, make sure the shipping materials are all removed, yellow shipping pins in back, styrofoam blocks etc. If this is an older machine, new problem, empty the machine, reach into the washer and give the basket a good hard spin, if you hear any type of grinding noise, or excessive rattling, your bearing and possibly the spin basket support are bad. I would also remove the top and front- bottom panel, and make sure the suspension springs and shocks are not broken before assuming the bearing, as this is a very lengthy and expensive job, (although the basket itself should have a lifetime warranty).
Posted on Sep 15, 2008
Frigidaire front loading washer has loud spin cycle, Why?
That's a great question, Roth!
Based off the information you have provided your Frigidaire washer is making a loud noise during the spin cycle. This could be an issue with your bel, motor, or tub. In order to find the cause of your noise you may need to disassemble your washer. This is not a simple DIY job and I would recommend contacting a technician to come out. This will help prevent any future issues or personal injuries. -Matt
Mar 11, 2015 | Frigidaire GLTF2940ES Front Load Washer
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
I have the ATR6700FS1 front load washer. It goes fine until the spin cycle. It pauses & when I hit restart it makes a noise & doesn't spin. If I hit cancel & go to the spin cycle it
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 29, 2013 | Frigidaire ATF6000ES Front Load Washer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
We just bought a used Frigidaire front loader bought in 2004 and the washer jumps when in even the lowest spin cycle. We have bought a rug for under the washer and it has not helped. Any ideas???
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 02, 2011 | Washing Machines
I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
Noise starts when going into spin cycle
heatman101
Sep 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
