Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
MAYTAG DOUBLE DOOR REFRIG
WATER LEAKS OUT OF THE FREEZER DOOR ONTO THE FLOOR. CAN'T FIND ANY LEAKS INSIDE. REFRIG HAS A ICE/WATER ON THE FREEZER DOOR. I CAN CLEAN OUT THE ICE ON THE FREEZER FLOOR AND 12-15 HOURS LATER, ICE HAS BUILT UP TO A POINT WERE ITS ABOUT RUN OUT OF THE DOOR.
  • 5 more comments
  • RICHDOHM Sep 15, 2008
    NO AUTO DEFROST SWITCH OR BUTTON AND ALSO THE FREEZER IS NOT BUILT UP WITH ICE EXCEPT ON THE BOTTOM. RICH
  • RICHDOHM Sep 18, 2008
    DID NOT CORRECT MY PROBLEM. THERE IS NO ICE BUILDUP, EXCEPT ON THE FLOOR OF FREEZER AS MENTIONED BEFORE, AND THERE IS NO SORT OF AUTO DEFROST SWITCH IN THE REFRIG
  • RICHDOHM Sep 19, 2008
    I ALREADY TRIED THAT. I TURNED IT OFF ON THE DOOR, RAISED UP THE METAL LEVEL CHECKER AND EMPTIED OUT THE ICE TRAY. ABOUT 15 HRS LATER, THERE WAS ICE ON THE FLOOR OF THE FREEZER. CONSIDERING REMOVING ALL THE SHELVES AND THE REAR PANEL TO CHECK THE DRAIN. THANKS ANYWAYS, RICH
  • Mike Burnett
    Mike Burnett Oct 12, 2012
    I also have this problem on this rsw 2400 new in 1997. The problem for me is the ice tray behind the panel. Defrost water goes into metal tray. Metal tray drains down to plastic tray below refer. I spoke to may tag customer service. it is a design problem, resolved by replacing the duck bill valve pn W1 03 09 238. I didn't get a price, i will let my maytag repair guy put it in and hope that solves it. The new valve is longer and wider. Mike Tucson
  • Anonymous Mar 12, 2014
    water collects in the bottom of the freezer... freezes and later runs out onto the floor.
  • Anonymous Mar 13, 2014
    I can't remove the inside floor.
    how do I fix it.
    Genius:
  • 2,035 Answers
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Posted on Sep 18, 2008
    President:
  • 1,450 Answers
Cut the water off to the icemaker if this stops the water build up on floor then you will know it is a leak from icemaker or filter. which i feel sure it is there is no other reason for this much ice to builup that quickly
  • TripleTauto
    TripleTauto Sep 19, 2008
    have you cut the water off where it comes into fridge? like under the sink where it hooks up? if you do this then you will know it is a line or not?
  • 68 Answers
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Posted on Sep 15, 2008
  • KINSHUK ACHARYA
    KINSHUK ACHARYA Sep 15, 2008
    THE AUTODEFROST SWITCH (IF AVAILABLE) MUST BE THERE AROUND THE TEMPERATURE CONTROL KNOB OF THE REFRIGERATOR
  • KINSHUK ACHARYA
    KINSHUK ACHARYA Sep 18, 2008
    clear the drain channel and so that the defrost water can flow down to the drain pan.
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Water leaks into bottom of freezer and then melts and leaks onto the floor
You have a clogged auto defrost drain problem. You need to look way in back and at the bottom for the drain trough and clean it out.Or you can pull the refrig. out from the wall and try to get to it that way.Hope this helped.
Jun 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
399 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
