Yes. When you don't use it for a while, the ink clogs at the nozzles.
Get it cleaned from a capable professional in the area.
If there is no one to support, you can try the following (at your own risk).
Hold the nozzles to steam from a kettle for 10-20 seconds, gently wipe the nozzles with a clean cloth or absorbent paper, and try printing.
or
Put some water into a bowl that is warm such that you can barely put your hand in. Dip the nozzles in water (Don't get the circuit part wet) and gently move the cartridge in water (again, only the nozzles should be in water). gently wipe the nozzles with a clean cloth or absorbent paper and try printing.
