Question about Rowenta Power Duo Iron
Residue on iron plate - Rowenta Power Duo Iron
  • 242 Answers
They sell cleaner for this. Or just use very fine steel wool #000 or #0000. Only use on a stainless steel iron, not one that has non-stick coating.
Posted on Sep 17, 2008
How to remove fusion glue from top plate
if the top plate is fabric covered I would guess you get a replacement cover if it is metal you can scrape it off then wipe with mineral spirits to get the residue off .
Nov 13, 2015 | Singer ESP2 Portable Steam Press
How do you run clean cycle - I have lost the manual
Self-Cleaning and Maintaining Sole Plate
Use the self-cleaning feature once a month by moving the steam lever back and forth from the "dry" setting several times. This will remove any residue from the steam valve and ensure that the steam system works properly.
Wipe the sole plate with a soft, damp cloth while the iron is cool and unplugged.
Run the iron over a cotton cloth several times to remove any residue from the sole plate.
Cleaning Anti-Calcium Feature
Fill the water cup that came with your iron. Use enough water to reach the Sunbeam logo in the top corner of the cup.
Add a teaspoon of salt to the cup and stir.
Empty the salt solution into the water reservoir in your iron.
Allow the iron to stand for 15 minutes, then empty out the water reservoir.Repeat this cycle with a second cupful of salt water.
Rinse out the reservoir with clean water. You should perform this cleaning once a month.
Jul 28, 2011 | Sunbeam Irons
How to clear soleplate from a builtup of residue
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
Nov 01, 2010 | Rowenta DX6700 Iron
While steaming clothing, a white flaky residue is being left on the clothing. Sole plate is clean. Residue seems to be coming from steam vents. What do I do to continue using this great iron? Evelyn Roll
Are you in a hard water or soft water area, maybe you could try using filtered water in your iron. To clear out the scale from the jets try adding a little white vinegar to the water and steaming it through, or a little "Calgon" diluted in water. Then perform a test iron on some dark fabric untill the scale has been removed.
Aug 02, 2010 | Rowenta DX6700 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Instruction leaflet for Morphy Richards Iron 40659
It is always better to use distilled water, but this is not essential. However when using normal water, if the water has high salt content, white residue may be left on the bottom plate.
Jul 31, 2009 | Irons
The iron has plenty of water in the reseviour but will not steam. I have press the steam button and steam comes out but it will not steam otherwise
Your iron may be due for a cleaning. After awhile the ports inside the iron become clogged with mineral deposits.
Try using a mix of 1/2 white vinegar and 1/2 water. place the mix in the reservoir and allow the iron to heat up for steam until the reservoir is empty. Then do a second round with plain distilled water. Clean the the iron plate of residue after it cools.
If the vinegar mix does not work (and you can do the mix a few times) try using a product such as "Lime Away" or "CLR" to dissolve the deposits. Hope this helps.
Jul 12, 2009 | Irons
How to clean
heres a link to help you out , also I recommend to get "CLR" cleaning product , hope it helps AJ
Jun 12, 2008 | Rowenta DX6700 Iron
BRown water and stuff coming out of iron
Hi, two problems:
DIA' s problem - the brown water is due to poor water quality and debris in the boiler and iron sytem. Rowenta is clear that they do not want anyone to cleaning solutions - only clear filtered drinking water to rinse out the boiler (via the water inlet screw hole) and I have found running the system dry, letting it cool, rinsing and draining the boiler several times before putting unit away works fine.
Guest' problem with brown/black tar substance is likely caused by too hot and iron setting (steam setting may also be too high) for ironing man-made synthetics (like Nylon, Rayon, Polyester or blends are basically petroleum based fabrics) that breakdown or melt, leaving deposits on the iron's stainless steel soleplate. A secondary cause could be bad water or debris in the boiler/iron in which the solution for DIA's problem might provide relief. Cleaning the soleplate is tricky, I use nothing stronger than an old fashioned wooden orange stick to gently scrap of all traces of the "stuff" and dry "Dutch" cleanser w/ a terry cloth or old cotton sock to polish without scratching the soft stainless soleplate...
Apr 01, 2008 | Rowenta DG-980 Iron
Rowenta Power Duo Iron Logo
124 people viewed this question
Top Rowenta Irons Experts
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
