Question about Canon PowerShot A620 Digital Camera
Lens cover will not close
Dropped my Canon Powershot A620 face down in dirt during rain shower. Now lens cover will not automatically close. Camera operates fine in every other aspect.
  • oneeyewinky Sep 16, 2008
    Is there any way to just remove and replace lens?
    Novelist:
  • 208 Answers
YES, BUT THAT IS A JOB THAT NEEDS TO BE DONE PROFESSIONALLY, DUE TO THE ALIGNMENT OF THE LENSES AND THE POWER DRIVE FEATURES. IF YOU GOOGLE CANON POWERSHOT A620 REPAIR SERVICE, YOU SHOULD BE ABLE TO GET A PRICE QUOTE BEFORE YOU SEND THE CAMERA IN FOR REPAIR. IS IT JUST THE COVER THAT NEEDS REPLACED OR THE LENS? THE COVER MIGHT JUST NEED TO BE CLEANED GOOD WITH AIR TO START WORKING AGAIN? WORTH A TRY. IF I CAN HELP MORE, REPLY TO:
ARCLIGHT1217
Posted on Nov 06, 2008
  • Phillip Irish Jul 06, 2011
    I have a Canon Powershot A620. A little spring fell out of the lens cover, it's mostly open, but not all the way. Question: Does the cap holding the lens cover screw off? And which way does it turn to take it off. Any help would be appreciated. Phillip
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
When switched on power shot makes high pitched sound followed by e18 in the display screan
Its means lens error. Look carefully between the lens and the camera body for any sand or other dirt etc.
Apr 16, 2010 | Canon PowerShot A620 Digital Camera
View screen black when on & no longer takes photo's
Sounds like a dead CCD. Contact your local Canon service center.
Tom
Jul 24, 2009 | Canon PowerShot S3 IS Digital Camera
Canon Powershot A 620
Check your owner / user manual. I had similar problem and it was caused by "Mode" and "Flash" settings.
Jul 23, 2009 | Canon PowerShot A620 Digital Camera
Lens Shutter Don't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A620 is more complex, but still similar enough. As recommended in the post, try the simpler fixes first before attempting:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Dec 26, 2008 | Canon PowerShot A620 Digital Camera
How do you replace the lens cover for the Canon A620.
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol around the barrel's perimeter instead of the front as shown in the procedures.:
Mar 25, 2008 | Canon PowerShot A620 Digital Camera
My PowerShot A620 lens isn't working
Don't even try unless you know what you are doing - you can get a nasty belt off a charged flash capacitor (around 300volts) - the lens is more than likely clogged up with sand, this will wear the sliding tracks in the zoom very quickly and will render it useless.
You can buy new lens assemblies (Colchester Camera Repairs) but the cost will be high, around £80.00 just for the part.
Jan 01, 2008 | Canon PowerShot A620 Digital Camera
Camera will not power up correctly
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Nov 08, 2007 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
302 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
