Question about KitchenAid KAWS700L Top Load Washer
How to replace belt on kitchenaid supera washer
How do you replace this belt
  • rekjb2258 Apr 06, 2009
    washer wont spin
I dont think that there is a belt on that model i have the same thing and mine is a direct drive with a drive coupling
Posted on Jan 27, 2009
Top load Kitchenaid washer KAWS850LQ wont spin. Took off back, found broke belt. Best way to replace belt
It won't spin without the belt. You need to place the belt from the motor to gearbox and there may be a tension pulley. Most are adjusted by loosening the motor and pulling it tight
Dec 02, 2014 | KitchenAid Washing Machines
My kitchenaid washer has a burning smell
Hi, a slipping or severed belt will produce a burned rubber smell. A belt supports the drum and ensures its smooth movement. If it wears, the drum's movements weaken and finally come to an abrupt halt. In addition, a slipped or severed belt usually produces a burned rubber smell. Refer to the washing machine manual to review how to locate the belt. If the belt is no longer around the drum's center, shift the belt back to its original position. If rubber fibers are discernible or cracks are apparent, change out the worn belt for a new one.
Thank you.
Jun 05, 2012 | Washing Machines
My kitchenaid ksrg25fkss refigerator supera wont get cold
freon. dirty coils under refrig. fan motor by comp. not working. make sure first of all comp. is running if not make sure freezer fan is. if that the case you need a relay starter overload or a compressor.
Apr 01, 2012 | KitchenAid Refrigerators
My 1998 kitchenaid clothes washer, model no. kaws750g squeals for 20 seconds or so at the beginning of the spin cycle. It still gets the water out of the clothes o.k. Could it be a belt or bearings? Thanks
Belt of bearing is a good call; I usually lean toward the belt, especially if it hasn't been replaced in a while. Like on a car, when a belt becomes worn, it develops slick spots that tend to slip before they grab, causing a squeal. It's a common repair and although your washer is 13 years old, that's still pretty young as far as washing machines go.
May 16, 2011 | KitchenAid Washing Machines
Panel to ice machine has no power on kitchen aid supera
I read another wb page and they mentioned a cable at the bottom of the freezer door being fray and broken. I found the cable harness they were talking about and I did not have any breaks. I unplugged the cable(be careful not to break the plastic) connected the cable together again and lucky me it worked. Do clue why because I had not been in that area recently. Once a month I do vacuum in that area so I may have loosened it some how.
Jan 28, 2010 | KitchenAid Refrigerators
Washer Won't Spin / Drain. Need New Belt or Pump? Need Diagram?
based on feedback that i received on the forum, i realized that the washer doesn't have a belt (it's a direct drive machine). then, i replaced the motor coupler, which was a lot easier than i thought when i posted this question.
detailed instructions can be found on an excellent post by jsrock516 on even though the washer is labeled 'kitchenaid,' look for whirlpool, top-load washer, tips. then, search for replacing a motor coupler.
jsrock516's instructions look complicated, but they're really just a very detailed, step-by-step guide written so you don't need any pictures. read through them before you start, and then follow each step as needed. great stuff.
Aug 23, 2009 | KitchenAid Washing Machines
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KAWS700L Top Load Washer Logo
684 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
