Question about Frigidaire Heating & Cooling
Ac compressor not working
I have bought a frigidaire thru the wall ac unit. after installation the compressor will kick on but only stays on for a couple to few seconds and shuts off.....maybe 8-10 seconds.
thinking that i got a bum unit, i got a second one and it does the same thing.
It states to have a 15 amp circuit, which put in a 20 amp with 12-2.
does the unit need to stay on for a long time before the compressor gets activated?
this is a 18,500 btu model fam187s2a.
    Top Expert:
  • Frigidaire Master
  • 12,744 Answers
A 9 1/4 ton unit should have a 230 volt service check that power is correct and not 110 v
Posted on Jun 05, 2017
  • Frigidaire Master
  • 822 Answers
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    • 57 Answers
    SOURCE: need a replacement thru the
    Measure the cabinet dimensions. then best place to check for replacement is Home Depot ,Lowe's, sometimes Sams Club, B.J.'s or Cosco these places buy in large volume and are hard to beat when it comes to price. The 115 volt units go up to 12,000 BTU. which is one ton. If you hit at the right time of year I,ve seen a/c units around 6,000 btu sold for as low as $69.00.
    Shop around most all brands are about the same. Cost is based on the number of bells and whistles you want. The most simple units cost the least also the less that can go wrong. I have found it really hard to find exact demention replacements.
    Posted on May 18, 2008
    SOURCE: 2 Air Conditioner Problems
    Whinny noise is probably motor which needs some motor machine oil (hardware store).
    Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
    If you want to further pursue, let me know.
    Posted on Apr 30, 2009
    roniecon
    • 6927 Answers
    SOURCE: haier 8000 btu thru the wall ac wont come on
    try ot unplug for 2 minutes,,, and try again may have fuses inside also
    Posted on Jul 03, 2009
    • 2187 Answers
    SOURCE: I have a frigidaire window air conditioning unit,
    Check the motor for power. The condenser only has the compressor and the fan as its moving parts. Check if there is power running to it or you may just have the fan that is not working. In checking see if there is a correct freon pressure, power cables or relay for the compressor are all ok or there are leaks in the system. You may want to have it cleaned while at it.
    Posted on Aug 19, 2009
    caroldon
    • 17130 Answers
    SOURCE: i have a 5,000 btu
    Could be the starter contactor, the capacitor or the compressor by itself . You can see the condition of the starter and maybe clean or if it looks bad , must be replaced. The same goes for the capacitor if the compressor is humming. But if the compressor motor is not starting up , please check for starting current with a clamp tester, if it goes higher and stalls then the compressor/motor is faulty.
    Might need help to do an overhauling.
    I hope this advice helps.
    Posted on Aug 20, 2010
    Fan will come on but compressor wont kick in on wall unit ac
    The start capacitor on the compressor is bad. Replace it and the compressor will run.
    Jun 30, 2013 | Heating & Cooling
    Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
    Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
    Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
    2000 pontiac grand prix ac problem
    If the compressor is working, a mechanic would check the low and high gauge pressure.
    The freon has to flow thru the system to work, and the cooling fan draws air thru the condenser to get rid of the heat from inside the car.
    If the ac clutch is working but the gauges show equal pressure, the compressor may be faulty.
    Jul 16, 2012 | 2000 Pontiac Grand Prix
    Compressor doesn't kick in
    If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
    Compressor bobicehouse_60.jpgOverload Thermostat (Open thermostat) Burnt wiring Bad selector switch Capacitor
    Aug 13, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
    Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
    Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
    make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
    if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
    Aug 05, 2011 | Heating & Cooling
    Have a frigidare wall ac (FAA067P7A). Worked 1st year we had it but problems after. Only time compressor kicks in is when we hit reset button. Then cold air comes out for couple minutes then compressor...
    The compressor is stopping on overload. There is either a weak breaker or an electrical problem causing the overload to open the circuit and stop the compressor. It has to be taken apart to determine what is or is not going on.
    Aug 03, 2011 | Frigidaire Compact Air Conditioner
    Can a 12000 BTU thru the wall AC be installed as a
    Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
    heatman101
    Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
    Compressors Won't kick on
    could be tripped on high pressure id clean both . Tom
    Jun 17, 2009 | Heating & Cooling
    Frigidare thru-wall AC drips water when unit is on.
    Do not try to drill any holes but search for the built in drain and open it. Again do not use a drill. Get a shop vac.
    Jun 09, 2009 | Frigidaire FAC124 wall/Window Air...
    Frigidaire FAH086N1T Thru-Wall/Window Air Conditioner
    clean your return air filter, and while you have the front cover off you may want to clean the evaporator as well (it's the silver grill looking thing) some compressors come off their springs during transport and will rattle for years but still work fine.
    Aug 02, 2007 | Frigidaire FAH086N1T Thru-Wall/Window Air...
    Heating & Cooling Logo
    1,431 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
