Question about Sharp UX 510 Plain Paper Thermal transfer Fax
Will not receive Faxes
When someone is sending me a fax, I get a plain sheet of paper on each of the number pages that the sender is faxing to me, then somewhere in the transaction I get a error message stating that there is a line error and the fax or most of the fax did not receive. How can I fix this problem?
  • tahoebob Nov 26, 2008
    sharp ux 510 fax feeds an extra blank page after receiving
    one printed page. but not in the copy mode...????
  • Sharp Master
  • 2,794 Answers
The first thing you can try is replacing the phone line between the wall and the fax machine.
Posted on Sep 15, 2008
I cannot send. It tells me there is No Answer. Receiver tells me everything is ok on their end.
Has the receiver gotten faxes (from other senders) since your problem started? It sounds like the receiving fax is not answering the call. Also to determine if it's your problem or the receiver's problem send a test fax to someone else.
Sep 22, 2011 | HP 1050 Plain Paper Inkjet Fax
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
I am able to fax but instead i can't receive any faxes
Sounds like it could be the settings not correct. (the phone number, it could be set to send only, etc.) I would check the settings.
Jul 16, 2010 | Philips Magic5 Voice DECT Duo - Fax /...
Received faxes on brother fax 1360 incorrect order
you cannot control PAGINATION, have the sender reverse the order of sending.
Nov 14, 2008 | Brother Fax-1360 Plain Paper Inkjet Fax
Fax will only send and not receive
Call your fax machine from a regular phone and listen for fax tones. Sender may be dialing the wrong number. Is your phone line DSL?
Sep 05, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Problem with sent faxes
CIS SCANNER SEEMS TO BE BAD TRY CIS TRAINING FUNCTION IN THE MAINTENANCE MODE AND DO CIS TRAINING USING A PLAIN WHITE SHEET/(FUNCTION *2864 , USE 55 CODE TO DO THE CIS TRAINING) OTHERWISE REOPLACE CIS SCANNER. HAPPY FAXING OMNIPRESENT
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Stretched-looking faxes
It is probably from the same sender I bet. He has an original paper feed problem. If not let me know.
Jun 14, 2007 | HP 1040 Plain Paper Inkjet Fax
Sharp UX 510 Plain Paper Thermal transfer Fax Logo
147 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
