Question about Abit Computer-model:AN78GS Motherboard
System reboots I installed an AMD A64x2 2 gig ddr2 Have a 450 pw 20pin. system boots into bios setup, but within a minute video shuts off. Booted to windows, but after a few seconds a blue screen with print flashes on screen then system restarts, shows ABIT screen then Video shuts off.
  • scprotz Dec 31, 2008
    After a recent update of Windows and also loading the NVidia driver (From their website) I have the same problem...I did both at the same time, and so am not sure which one is causing the problem. The computer blue screens within about 10 seconds of reboot and flashes so fast that I can't see the error...suggestions?
  • 67 Answers
Blue screen usually means memory problem or critical hardware conflict. You could have a damaged memory module, or dust might be on the way of the memory.
Posted on Sep 16, 2008
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
I have got Sony Vaio. When I installed Intel Graphic driver and rebooted, the laptop don't get booted. The screen displayed a message as: System BIOS Shadowed System VIDEO Shadowed. After waiting for...
Please download and Run the BIOS update utility for resolve this issue. You can download it from the link below.
Download
If the problem still persist, reboot the Computer and keep tapping the F2 key when VAIO logo appears on the screen to enter BIOS mode. You can manually disable the function System and BIOS Shadowing. This will resolve the issue.
Good luck..:)
Sep 20, 2010 | Sony VAIO VGN-CR220E/W Notebook
Windows 7 is shutting down my graphics card (Nvidea) ...error 43...and freezing screen resolution at 600x480. Tried updating the driver, restoring the system to an earlier point, tried reboot at last known...
Press "F8" before Windows boot and you'll be presented with Advanced Boot Option. Select Safe Mode and hope it can booted successfully into this mode. Uninstall the related driver and reboot the system to normal mode.
Once it is booted, install the driver obtained from NVIDIA which is WHQL certified for Windows 7. Once installed, reboot your system and hope it works now.
Jul 14, 2010 | Microsoft Computers & Internet
My AMD computer started rebooting on its own minutes into a boot. I tried reinstalling a fresh copy of XP but it would reboot into the installation. It reboots in the BIOS setup so it is not the O/S. It...
this is a mobo setting try reseting the board using the bios jumper switch it to the reset possition turn on pc /switch off pc and replace to original setting see if this helps b4 replacing board
Jan 01, 2010 | Computers & Internet
Videocard not working
Try removing the new card, booting into BIOS, change your video setting the slot of your card: I believe your card is PCI-E, save changes and exit. When it starts to reboot, turn the computer off, install the new card and then try rebooting again. You may also have to boot into Safe Mode\Uninstall the original video driver or disable that video component and then try rebooting your system.
Mar 29, 2009 | ASUS M3A78-CM AMD 780V AM2+ Phenom FX /...
Computer restarts randomly with blue screen. How can I fix it?
Find the root of the problem by analysing the previous BSOD crashes. Its probably a hardware related issus (graphics driver or USB).
You need to enable the Memory Dump feature. This can be analysed when the system restarts to find out the root cause.
http://support.microsoft.com/kb/235496
Mar 06, 2008 | Microsoft Windows XP Professional
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Abit Computer-model:AN78GS  Motherboard Logo
78 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
