Question about Amana D545M Dehumidifier
Amana dehumidifer blows fuses
I have a 2? year old Amana dehumidifer model D545M located in a vacation home. Unit was not working, (completly dead), disassembled and found a blown fuse. I replaced the fuse and turned the unit on. The fan turned on for about a second then blown fuse again. I then jumped the fused line (to direct wire), to try and determine what the problem was. The result was the same, fan turns on for a second then before the compressor starts circiut breaker kicks out. I have had no other problems with this unit before. Since this is not at my primary home I do not know if there were any noises or problems just before the fuse went. I also have same unit at primary home and have had for about 4 years with no problems at all.
SOURCE: amana d545m dehumidifier no power
replace 24 volt 1 watt zener diode on circuit board. 1n4749 (nte5081a)
mine was hit by lightning and this fixed it.
Posted on Jul 31, 2009
I have an amana d545m in the crawl space at my lakehome...when i went to check on the furnace filter, i noticed it was not running and has no power...how and what do i check to diagnose the...
First, make sure that there's power to the unit. Has a circuit breaker in the circuit breaker panel been tripped? If so, unplug the unit before resetting the breaker. Also, check the receptacle or extension cord that you're using to power the unit, as it may be damaged.
If you have power to the unit, it may be that some critter or insects have gotten into the unit and shouted it out. In which case, you're lucky that it didn't start a fire. It's not a good idea to leave the dehumidifier running unattended for a week or more.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Sep 13, 2011 | Amana D545M Dehumidifier
Where do you get Curcuit Broad D545N Dehumidifer and a bucket Switch
Its not worth the money. the cost of those two parts exceed the cost of a new one. Dont buy amana again they have very poor quality.
Jul 20, 2011 | Amana D545M Dehumidifier
EVERYTIME I PLUG IN THE UNIT AND TURN IT ON IT BLOWS THE 12 AMP 125 V FUSE INSIDE. REPLACED THE FUSE MULTIPLE TIMES WITH THE EXACT FUSE RECOMMENDED AND IT STILL BLOWS. THE UNIT IS ONLY 1-2 YEARS OLD. ...
The compressor has locked up and will not start...this is terminal and will cost more to replace it then the unit is worth...
unfortunately you will have to replace the unit with a new one...
heatman101
Jun 30, 2011 | Amana D545M Dehumidifier
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
I have the same problem--no water comes out.
make sure the front vent/filter is clean and free of debris. if there is not sufficient airflow across the condenser coil (front), it will not cool down. if it does not cool down, it won't remove the water from the air.
Aug 07, 2009 | Amana D545M Dehumidifier
Amana d545m dehumidifier no power
Jun 23, 2009 | Amana D545M Dehumidifier
AmanaD545M Runs but no water comes out
if the compressor is running and the coils dont cool, then you have a refrigerant leak or a plugged capillary tube. it would cost more to fix than to but a new one. sorry but its time for a new one.
May 11, 2009 | Amana D545M Dehumidifier
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Amana D545M Dehumidifier Logo
97 people viewed this question
Top Amana Dehumidifiers Experts
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
