Question about Miele 24 in. Novotronic G842 Plus Built-in Dishwasher
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Posted on Jan 09, 2011
  • jave107 Feb 04, 2011
    Thank you Thank you! you just saved us a lot of money and headaches!!
Miele repairman showed me how to fix this. Why Customer Care doesn't suggest it is a mystery! Miele even issued a tool to repair people to use and my repairman showed it to me!
Remove the big filter screen in the bottom of the dishwasher. The white plastic intake/drain pipe is centered underneath. Take a metal spoon handle (I used a teaspoon with about a 3/8" flat end on the handle---I guess you could use a slot screwdriver with about the same width tip) and insert the handle end into the side pipe and turn it---it moved/freed a propeller or something---didn't require much force, just a gentle, deliberate turn, not enough to break anything. Dishwasher started up as soon as I shut the door.
Repairman said the problem most often occurs when dishwasher isn't used frequently and the part gets stuck over time.
Posted on Sep 25, 2008
Dishwasher turns on but the intake drain light goes on and dishwasher is on but not actually running...how do i fix it?
The fault is possibly linked to the water intake circuit.
Either the inlet tap is closed or the water inlet filter is blocked or the intake valve is simply faulty.
See pages 33 and 46 in the user manual.
Hope this helps fix the problem. Please rate the solution if suitable or post a comment.
Nov 26, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele g 842sc plus dishwaher
hi,
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 21, 2010 | Miele 23 in. Novotronic G841 Built-In...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele Intake/Drain light on/flashing and the dishwasher just shuts down.
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
Nov 22, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele dishwasher won't drain
try removing the pump cover in the sump to see if it is blocked or jammed. it tells you how to in the user manual.
Jul 16, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
May 31, 2009 | Miele 23 in. Novotronic G841 Built-In...
Miele Novotronic G842SC Plus
Add the requested rinse aid.. The light is on telling you it's low/empty.
Oct 20, 2008 | Miele 23 in. Novotronic G841 Built-In...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele Novotronic dishwasher G841
I asume U R talking about the Drain Hose?? As long as it doesn't get Kinked, I see no Problem.. I installed one yesterday the (25th) and the Drain comes out under the Dishwasher, so therefore, the Drain Hose has to be ran under the Unit.. No Problems !!! I hope this Helps U out...
Jul 19, 2008 | Miele 24 in. Novotronic G851SC Plus...
Miele 24 in. Novotronic G842 Plus Built-in Dishwasher Logo
2,752 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
