The power went out at home. now there is no power to the router. i have reseted and waited for 30 sec. but still no power
    Sergeant:
  • 300 Answers
Change power supply.
Posted on Sep 16, 2008
WAN light keeps blinking on my Wireless N Home Router and I cannot access the internet although I can access the router config page. This started just yesterday and before that the WAN light used to be...
How old is the device? May be time for a new device? Has there been any electrical storms? Power surges? Tried different connecting cables? When you reset the device, hold reset for 30 secs., release, wait for selftest, unplug device for 30 secs., plug in, wait for selftest, connect with a Ethernet cable, reconfigure SSID and Security Key.
Apr 28, 2013 | Trendnet TEW 652BRP Wireless N Home Router...
I nee to syn this router with my cpu. what do i do.
Belkin reset:
1. Locate the reset hole on the router. The button will be on the back or side of the router.
Leave the router powered on.
  1. Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  1. Remove the paperclip.
4. Wait approximately one minute for the router to restart.
The settings for the router have now been reset back to their default.
Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 12, 2011 | Belkin F5D8236-4 Router
I'm trying to to use the wifi but it is asking for a wpa password and i can't find the wpa password
Perform a Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Router setup
Thanks, Joe
May 31, 2011 | Cisco - Linksys Wireless-n Home Router -...
I can not log in my router home page
1. Connect only a comptuer to the router using a ethernet cable to any one of the gray port on the router.
2. In the computer connected to the router, Click on start - > Run / Start scarch -> [type] CMD & hit enter.
3. In the black screen [Command prompt] type Start http://192.168.2.1 & press enter.
4. If still does not work.
5. In the black screen [Command prompt] type ipconfig & check what it the IP address under ethernet adapter local area connection,
6. It should be 192.18.2.x where x is a value from 2 to 254 & the default gateway should be 192.168.2.1.
7. If you get 169.254.xx.xx or any other numbers then try unpluggin the power from the router & pluggin the power back in after 30 sec.
8. Still the same numbers try pushing on the reset button at the rear of the router using a paper clip or pin for 10sec & release it after 10 sec once again unplug the power from the router wait 30 sec & plug back after 30 sec.
9. Again try step 3.
Thanks
Dec 27, 2010 | Computers & Internet
Cd drive not working can't play cd to install thomson tg782t home network gateway from telstra
Try this:
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Dec 12, 2010 | Computers & Internet
The wireless icon is orange. Do you know why??
Hi, 1. Unplug the power from the Modem to the Router 2. Plugin back the power into the Modem and wait 60 sec.. 3. Plugin back the power for the Router wait 60 sec.. 4. Plugin a lan cord from the router to the first wired PC 5. See if you can get on the internet 6. Login to the Router and see if the Connection to the WAN is started? 7. If not started then unplug the wired lan cable and reset the router wait 30 secs to 45 secs before unplug the power then plug the power in again. Then connect the lan cable then connect to the GUI for WEB. Make your See if it connects to the WAN. 8. Test the Network WAN -Internet and LAN - Home Network.
Take care
Jul 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Angel
In this case,we can do a power cycle of the router.steps to do a power cycle
1.unplug the router power adapter and then the modem power adapter if its a cable modem then we should also unscrew the coaxial cable wait for 10 sec and then screw it and now plug the modems adapter first wait fir lights to be stable and then the routers power adapter.now check the lights.
If power cycle doesnt resolve your issue then do a reset.restting a router is setting it to the factory setting so pls note the changes you have done in the netgear smart wizard page if any.
steps:
1.HARD RESET-you ll find a circular hole(reset button) at back panel of the router(see d chart on the router ).take a paper clip and press and hold for 30 secs and release it after 30 secs.
2.FUNNY RESET-If the previous step doesnt work,then we have do the funny reset.Here press and hold the reset button for 1 minute simultaneously plug and unplug the router 3 times.
Hope these steps solve your problem if not reply me and if this issue is solved pls rate me to improve my service.
Jan 06, 2009 | NetGear WGR614 Wireless Router
Can't connect to web configuration
There is a reset known as a 30/30/30 reset. Hold reset with power on for 30secs, unplug power while still holding reset for 30 secs, plug power in while holding reset for 30 seconds more and release, wait 30 secs or more for reboot. This should put it back to factory defaults regardless of brand. Set your IP manually on the PC to be 192.168.0.2 Open your web browser and type in the IP address of the router (192.168.0.1 by default). Enter the username (admin) and password (blank by default), and then click Ok or Log In
Aug 26, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Lynksys Help
It the power light is blinking.. then it seems to be a problem with your router..one thin i can suggest you is .. just unplug the power cable.. and wait for 20 sec and then reconnect it and check.. if still the same , look at the back of your router..you would find a reset button.. press and hold the reset button for 60 sec witha pen or a paper clip with the power connected.. and then disconnect power and wait for 30 sec and reconnect again and then check if still the same ..the your router has gone bad.. better replace your router..if its still in warranty..
Dec 04, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
