Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
VIRUS how can I remove blaster/sasser.variant from my computer I live care and it says my computer is in good shape, but I have the warning coming up all the time that say system antivirus 2008 help ingrid
    President:
  • 2,961 Answers
Anti virus 2008 is a trojan, turn off system restore (right click my computer>properties>system restore tab; if you have one care then start your pc up in safe mode (F8 on boot up), choose safe mode and then your operating system, then click the administrator account and run the programme, then when dissinfected restart pc, turn system restore back on
Posted on Sep 15, 2008
Ingin menghapus virus dari server
You can try to use a virus removal tool like Avast Virus Cleaner.Avast! Virus Cleaner is a free tool that will completely remove selected viruses from PC.
It is able to stop viruses that are active in memory, it will disinfect your files, remove virus registry & startup items, and virus working files.
Currently, it can handle these virus families: Badtrans, Beagle, Blaster, BugBear, Ganda, Klez, MiMail, MyDoom, Nachi, NetSky, Nimda, Opas, Parite, Sasser,Scold, Sircam, Sober, Sobig, Swen, Yaha,Zafi incl. var.
or an online one like Trend Micro.
Good Lock!
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 21, 2011 | Panda Antivirus Pro 2011 (3 Users)
Lsass.exe system error insufficient system resources exist to com
You probably have been hit by a virus that is attacking your Local Security Accounts Windows file and is using all your system resources. You may not be able to perform a system scan to fix this issue do to the lack of system resources. Now if you have another pc with a good and upto date antivirus application you can take the hard drive out of your computer and plug it into that other computer and scan it and remove the infection and while you have it in their go to the command prompt and repair the windows files by typing:
chkdsk E: /r
The E: is the drive letter of your infected drive you will know what this is when you go into my computer.
Also use a spyware program like Adaware that is up to date to scan the drive as well.
This all assumes you want to save the drive, Windows, and all your applications. Now if you don't care about those things then try a system restore to go back to a working point in your computers history.
Otherwise repair mode for windows will work also.
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
It turns on then desktop window opens then it restarts on its own
Hi
First start your computer and press F8 and then run your computer on safe mood . if it comes to safe mood then run a good anti-virus scan I recommend AVG and then start your computer , and check
It look like sasser worm, find it in application running ,
Please Rate !
Sep 07, 2009 | Dell Dimension E520 PC Desktop
My pc take restart again and again.
Check for bloated capacitors in your motherboard. It may be the reason why your system keeps on restarting. If there are bloated capacitors then its time for you to change the whole motherboard or the whole computer set itself. Or - Another reason could be that your computer is infected by a Sasser. If you see an error message window with count down, then it is infected by a sasser. Download sasser removers. Here is another way to stop it--- Use System Failure Settings to Stop Automatic Restarts.
1. Click Start and Open the Control Panel
2. Go to System and Maintenance, Click on System.
3. Select Advanced System Settings and choose Advance tab.
4. Under Startup and Recovery, click on Settings.
5. Under System failure uncheck Automatically restart.
Hope this helps!
Aug 09, 2009 | Symantec Norton AntiVirus 2008: Windows
Everytime i log on within a couple of minutes i get a message qsaying that a program was unable to load and by the computer i have 1 minute until it shuts off what do i do?
Solution:
i) instant releif: click start button---->click RUN----> then type  shutdown -a   in the Text box------>
   you'll see that message disappears.....
ii) i would this problem is due to virus so try reloading your OS or formating your OS or loading the OS Freshly, before that try to run Antivirus Scanning on your system....
Thanking you,
M. Sridhar
Dec 27, 2008 | Compaq Presario 5000 PC Desktop
Will not boot to XP
these are some following procedure
do it carefully
XP Repair install Please read carefully and make sure you followed the warning links before initiating the Repair Install. You can print a text version for reference. repair.txt
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" width="15" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. If you get files not found during the copying stage.
    Blaster worm warning: Do not immediately activate over the internet when asked, enable the XP firewall before connecting to the internet. You can activate after the firewall is enabled. Control Panel - Network Connections. Right click the connection you use, Properties and there is a check box on the Advanced page.
    KB 833330u Blaster removal
    What You Should Know About the Sasser Worm and Its Variants
    Microsoft Security Bulletin MS04-011
  7. Reapply updates or service packs applied since initial Windows XP installation. Please note that a Repair Install using an Original pre service pack 1 or 2 XP CD used as the install media will remove SP1/SP2 respectively and service packs plus updates issued after the service packs will need to be reapplied.
Oct 13, 2008 | Microsoft Windows XP Professional for PC
Trend Micro Antivirus/Vista Antivirus 2008
Hello there.
Unfortunately you have been infected, by the software called "Vista Antivirus 2008". What this software does is infect you, then prompt you to pay to remove the infection that it installed. So it is a scam.
What i would recommend is use the uninstall instructions from here http://www.windowsvistaplace.com/xp-antivirus-2008-removal-instructions-xp-antivirus-2008/spyware-removal
This will remove the infection (and others) from your system.
Once you have completed the steps, be sure to try an online scanner such as housecall here http://housecall.trendmicro.com/
This will not conflict with your already-installed Trend Micro software, it mearly runs through your web browser.
On that note, Internet Explorer is not very safe for browsing the Internet with, i would recommend either Firefox or Opera for a safer/better browsing experience.
Hope this helps.
Jul 14, 2008 | Computers & Internet
Win2000professional sp-4
Use original cd off win2000professional sp4 and REPAIR IT
Beni
Oct 15, 2007 | Computers & Internet
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
146 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
