Question about Brother MFC-8440 All-In-One Laser Printer
ORiginal not feeding
When trying to fax from the tray, the mechanism to feed the
originals into the scanner is not working. There is a whrrrr...,
then the maching acts as though I am trying to fax manually
from the scanner glass. Any suggestions?
Thanks,
    Problem Solver:
  • 5 Answers
Push paper farther in till it 'catches' the feed wheels properly.
Posted on Oct 15, 2008
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Will not feed to fax a document, but will feed to copy..?
Have you tried to see if you have a dial tone on the fax??? Can you recieve faxs? If not make sure you have the phone cable insurted in to the right connection "LINE" not "TEL" Good Luck
Jun 26, 2009 | Sharp AR-M237 Digital Copier
When trasmitting the receiver copy is totally dark
The exposure lamp is not coming on, try unplugging the machine for a few minutes. power it back up, Try making a copy, it uses the same parts as out going fax.
If that doesn't work, feed a page into the fax, press copy, if you look where the original comes out you should see a bright light, this illuminates the original so the scanner can see the page. If that lamp is not coming on the lamp or the control board for the lamp has likely failed.
Hope this is of some help.
Ed
Apr 26, 2009 | Office Equipment & Supplies
Scanner feed hangup
NEEDS A SEPARATION PAD AND A BUSHING.IT IS NOT A EASY FIX
Feb 11, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Which way does the paper go into the feed when faxing?
Load the originals, with the print side up, into the document feeder tray. If you are sending a single-page fax, such as a photograph, you can also load the original on the glass. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 4215 won't feed envelopes
I assume you are using the manual feed try, if so there is a tire (rubber) near the center of the tray, just use any penetrating oil (such as triflow or wd-40) and clean the tire. Same thing goes for the tray assembly, there will be one half circle tire (flat on one side round on the other its the round side that needs cleaning).
Dec 29, 2008 | Office Equipment & Supplies
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Paper jams when trying to send fax (original goes in short way then jams) unit has had little use it establishes connection and then stops and jams when commencing scan
look in paper path(scanner compartment were paper feeds) to ensure there is no pieces of small paper or foriegn items in this area preventing paper from going all the way through if this fails clean the feed roller in document scan area with a micrfiber cloth moistened with rubbing alcohol
Jan 13, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother MFC-8440 All-In-One Laser Printer Logo
64 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
