Question about Xerox Office Equipment & Supplies
Phaser 8200 printer error service report 09.008.43797s
    President:
  • 2,072 Answers
The black ink sticks are jammed.
Open the ink loader and ensure that the black ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
One of your black sticks is not advancing properly.
Make sure one isnt cracked or twisted. If you happened to have put in a stick for a different phaser model, it may not be the same shape and would not hut the actuator at the bottom of the ink loader.
Raise your cover where you add your ink sticks and look at the black sticks. One is stuck somehow.
If you need to remove them, take a screw, a drywall type screw is best, and twist it into the ink block and slide it up and out, then reload the ink loader with good sticks. That shoulf do it. I ihave never witnessed the ink loader itself be the problem.
Posted on Sep 17, 2008
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Error code 15.004.45.172027 on Phaser 8200
I would suggest calling a service agent and have him bring a paper pre heater.
Feb 25, 2009 | Xerox Phaser 8200 Laser Printer
Today's error is 15.004,45:207444
Here's a direct quote from the service manual on your error. Basically the is a thermistor (hi-low thermometer) that is defective or sensing that the drum is not heating to the correct temperature in the allotted time. You either have a bad drum heater, thermistor, or the drum to heater gap is way out of specification.
Service Manual Says:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap should be checked or adjusted
Hope that helps you.
Feb 19, 2009 | Xerox Phaser 8200 Laser Printer
Printer not working
That is a drum warm up fault. There are 2, 150 watt halogen lamps in the drum heater that blow.
If you want to replace them let me know, I will sent you the directions. I can pretty much say 100 percent that is the problem.
Feb 16, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200
Normally its the maintenance tray clutch slipping.
Or the maintenance tray ends are worn.
You can remove the left cover and clean the clutch, its on the lower part of the frame, and take your kit out and there are 2 tabs sticking out the ends that were on the last 1/4th inch.
The Printer's Front Panel Displays Printer Error - Report Fault: 07,005.47
Cause:
The Drum Maintenance home sensor actuated, but not at the expected time. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts): The wiring harness from the clutch is not seated properly on the I/O Left board. Check all wiring connections to the I/O boards and verify. connectivity. TROUBLESHOOTING TIPS AND HINTS: Inspect the maintenance drawer lift pins for wear. See Service Bulletin #445 Rev #1 Replace Drum Maintenance Cam Followers for Inadequate Drum oiling Due to Worn-out Lift Pins. Run diagnostics to verify clutch and sensor operation. Also verify that the drum maintenance shaft is properly assembled. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 401087100 1 CLUTCH; LARGE,DM,SAFETY CONTROLLED 436041400 1 MAINTENANCE DRAWER W/10K ROLLER & COUNTER/PHASER 860/8200 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
May 05, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
103 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
