Garmin nuvi 1450 GPS Receiver Logo
Posted on Sep 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i charge my garmin 1450 on the computer - Garmin nuvi 1450 GPS Receiver
Anonymous
Level 2:
  • Expert 464 Answers
  • Posted on Sep 20, 2011
Anonymous
Expert
Level 2:
Answers
464
Questions
0
Helped
119305
Points
696
Yes, the nuvi 1450 can be charged while connected to the computer as long as the USB port on the computer is a powered USB port.
tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Would you like to back up a copy of your Garmin Nuvi 1450 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
______________________________________
Garmin Nuvi 1450 Manual Download
Garmin Nuvi 1450 QuickStart Download
Garmin Nuvi 1450 Webupdate
Garmin Nuvi 1450 Hard Reset
on May 27, 2010 • GPS
I Update My Garmin Nuvi 1450 GPS but it does not pick some locations. Now, How can I fix this Issue?
Best SOlution for Garmin Nuvi 1450 UPDATE:
  1. Connect the device to a computer
  2. Install the Garmin Express
  3. Purchase or access the Garmin Nuvi 1450 update
  4. Disconnect the Garmin Nuvi 1450
Apply these above steps to update the Garmin Nuvi 1450 GPS device. Now you connect it to your vehicle and you are good to go.
Jul 18, 2019 • Garmin GPS
The limited directions tell me to charge my Garmin 1450 for at least 4 hours. How is that done without a charger? Will it charge with the computer cable? It seems that your site will not allow me to...
The nuvi will accept a charge when connected to a computer if the computer connection is done through a powered USB port.
Garmin part number 010-10723-00 which is an AC power adapter is also available for charging the unit.
www.gpscity.com/garmin-nuvi-zumo-international-ac-adapter.html
tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Does your Garmin Nuvi 1450 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
________________________________________
tip
Download Garmin Nuvi 1450 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
1helpful
How will you charge a gps nuvii garmin 1450 using computer?
To charge a garmin nuvi gps with your computer you connect your satnav to the computer's usb port using a mini USB lead. Turn on the computer and the satnav and the satnav will begin to charge. It will take approx 8 hours to charge compared to 4 using a car charger or mains charger.
Feb 05, 2011 • GPS
tip
Garmin Nuvi 1450 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
tip
Garmin Nuvi 1450 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
tip
Download Garmin Nuvi 1450 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1450 GPS?
Would you like a digital copy of the Garmin Nuvi 1450 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1450 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
tip
I hope that helps.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
