The laptop is a few years old with alot of miles on it. When i plug
the charger into the laptop the battery light will glow amber and
charge properly for a few minutes then the battery light will begin to
blink and the battery will discharge until the laptop shuts off. If i
pull the plug and plug it back in the laptop will begin to charge
properly again for a few minutes and then the light will begin
blinking again. I bought a new battery hoping this would solve the
problem, but the problem remains.
Please Help B4 my laptop goes flying out my window!
5 Other Users Have The Same Problem
Comment by benhummel, posted on Jun 24, 2008
me too
Comment by nomusa, posted on Dec 29, 2007
Satellite M35X. Replaced with new battery and power cord - almost $100 on laptops for less. My complaint is not with them. I think it's a Toshiba laptop problem. Front lights flicker on and off when turned off. Have to jiggle cord to keep them glowing. When using laptop, goes back and forth between AC and DC power. Battery continues to discharge - a percent every minute or so - though plugged in. Will eventually reach 100% charge. Often takes overnight. Used to be, maybe, an hour. Have 2 other friends with Toshibas, same problem. And no - do NOT feel comfy in opening/soldering power jack. Scrap it and buy another laptop???
Comment by Guest, posted on Dec 27, 2007
same here
Comment by Guest, posted on Dec 19, 2007
same problem
Comment by Guest, posted on Nov 05, 2007
battery won't charge
Was this solution helpful? Show your Appreciation by rating it:
Comment by LaptopRepair, posted on Dec 11, 2007
If you know how to take apart your laptop and have some soldering skills, you can resolder or replace the power jack yourself.
Here are step-by-step instructions for replacing failed laptop power jack.
ps. if you want to save your jack, unplug and plug the power cord in the transformer to get it to charge again..
Comment by ganjabymilk, posted on Jan 09, 2008
P's. the battery will charge absolutely when the computer is off.
So, with that, here's the basic basics.
1. Go get cd with drivers/utilities and reinstall.
2. Go online and get updated driver set, select power manangement option.
3. Batteries, MUST be exercised at least once a month, in full up/down discharge sequence, otherwise, you wind up with the equivalent of a float charge, which won't do much good.
4. When the 'new' battery was installed, did it have a full charge? If not, then the 'blinker' might just be accurate(seems manual will tell you what blinking conditions means).
5. Final suggestion. Go to power profile, and compare the charge condition of both batteries. Should be quite different, due to age(rechargeables have a typical life of 3 years, assuming that the heat doesn't get em first).
-= Answer / Hypothesis =-
To start with I'll say some system info -
Manufacturer: TOSHIBA
Model: Satellite A215
Processor: AMD Turion(tm) 64 X2 Mobile Technology TL-56 1.80GHz
Memory (RAM): 1918 MB
System type: 32-bit Operating System
The title states the initial concern, then I noticed that my laptop stopped charging. I understand many of you think its the port, in my case I believe it is different (though may be the same thing). After the blinking I went to make sure it was plugged in (check), I made sure the plug was fully inserted into my AC/DC Adapter (check), ... My AC/DC was on fire (not literally). Its been extremely hot for the last 5-10 minutes. I RARELY shutdown my laptop and its almost always on hibernate. While my AC/DC adapter cools down I'm just going to run on a low power setting, I bet if I had another adapter I could keep charing but no biggy. Hope this helps... Just to make sure it wasnt the socket making my community lets say "overheat" ill be using a different one for awhile. Hey hope this helps... Im glad I can post without having to join, what a beezy.
Post a New problem for Toshiba Satellite A105 PC Notebook
Email this problem
Can you Help with these PC Laptops problems?
Help me to unlock a laptop...
Cant Find Driver Anywhere!!!!
