No picture at times i would have green vertical lines, if you turned th tv off they would go away, it would not do it all the time, but one day it was turned on and it made a squelling sound and the picture went out but i still have sound, is this a problem tha can be fixed or do i trash it
  • Anonymous Apr 28, 2009
    instead of vertical lines I'm getting horizontal lines on all channels except for channel 3. I've changed cable wire, changed outlet for power cord and gone thru the initial set up several times. The TV played great for 3 weeks then started acting up. I'm At my witts end trying to figure this out.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check the capacitor of the power pack
Posted on Sep 22, 2008
Pink vertical line in center of screen th-42pz80u
it could be either the SD or SU boards going. check the cable connections and make sure the ribbon cables are seated properly.
Feb 24, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
JVC projection TV green timer light comes on, tv turns off
It sounds like your main projection lamp is burned out. They are fairly easy to replace yourself if you can find the lamp at a local repair shop or online. www.projectorlampcenter.com is one, also Fry's Electronics and Best Buy carry a few.
Sep 22, 2009 | JVC LT-40X776 40 in. LCD HDTV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have a Panasonic TH-50PZ700U, with a green 2'' vertical line in the upper right hand corner. The green line is there regardless of input and is constant. Around the line can have lighter lines at times...
It is the buffer X board. They are loacted at the botton of the set. Replace the one connected to the display panel directly in line with the lines in your picture.
May 08, 2009 | Panasonic Televison & Video
Vertical green lines
It sounds like th green LCD panel laminations or bonding has separated and this is causing your green lines. The optical block would have to be replaced to solve the problem.
Oct 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
Televison & Video Logo
308 people viewed this question
Top Televison & Video Experts
Electro Med Services...
