Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi tv have model #65513 and replaced the cap's that caused blinking green light and that lasted for about 6 months and now this new problem. I'm no expert with multimeter's. What I did is set meter to 200 acv and attached leads to both ends of ic9c25 with the set unplugged it read 0. plugged in it read 2.3 when I turned set on it read 1.7. If I did it right does anyone know if those readings indicate a bad IC? Recommend replacing the capacitors next to it with the same kind?. If you recommend replacing are there any tips on procedures. I replaced the Dm board caps fairly easily. Thank you!
  • thegrother5
    thegrother5 Sep 15, 2008
    Thanks Digi won't have any until December. Have to keep looking so set could possibly be fixed by superbowl. Thank you for explaining the results of voltage readings! Been trying for weeks to figure those out.
    Part Number: BA09FP-E2-ND
    Description: IC REGULATOR 9V 1A TO252-3 TR
    Ship dates are approximate and subject to change.
    Quantity Expected
    Ship Date Estimate
    (mm/dd/yyyy)
    Please Note: This is a non-stock item.
  • Mitsubishi Master
  • 19,396 Answers
The ic IC9C25 is a 1 amp 9 volt regulator, see
IC REGULATOR 9V 1A TO252-3 TR - BA09FP-E2
The multimeter must read an output voltage between 8.45, and 9.45 , if it reads 1.7 then the IC is faulty.
Check the datasheet here
Posted on Sep 15, 2008
GREEN FLASHING LIGHT MITSUBISHI WS-65513
On the front of the tv there is a small hole with a push button in it. Take a toothpick and push the button until the light stops blinking. This should reset your tv.....Joe
Dec 21, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi Projection TV model WS-65513
Good Day;
The continues blinking 99.9 % of the time is four caps on your DM board. The caps are C9B01,C9B02,C9B10 and C9B11 they use 1000UHF the upgrade caps are 680 UHF- 35V. The board is on the very left hand side (from back).
I have performed this repair at least 50 times and it takes me still about 1.5 hours. If you are not handy and do not have a solder station, I would recommend that you call a factory authorized service dealer to perform this repair. With service call and ect. it will cost you around $550.00 and the repair can be done in the home, of course prices varies across the country.
Good Luck, Day, Big Irish.
Apr 11, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65 in Perpetual Blinking Problem:
Replace four 1000mf/25v caps on DM module.....pix's at...
www.Chris@ChrisAndNat.com..................T.
Nov 25, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Cannot turn tv on
i have a fix for this DM board, if you want it please leave your e-mail addy and I will send it to you. This guide has pictures and tells you how to get to the board and what is the problem with it most of the time. good Luck
Feb 28, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
308 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
