Question about Hotpoint Kitchen Ranges
Mine is a compact, half width oven with stovetop. The manufacturer's placard is missing so no serial number or model number is there. Someone has written on it in perm marker, 388RA215 as the model number. Here is the problem. The units burners were left on for an extended period and many of the wires going from the switches to the individual burners and to the stove are turned to ash. The wire's insulating coating is completely gone and the wires themselves were pulled and jumbled when the grease chamber was removed. I need to know what wire to buy and I need a diagram to help me repair the unit.
  • 878 Answers
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this back.
Posted on Sep 07, 2006
  • 331 Answers
SOURCE: fitting a new control switch for the fan oven (model number 10450G)
Sesspod, 2 things... 1.) Pull the oven out and look on the back of it, there may be an envelope back there containing a technical data sheet which includes a wiring diagram. If not on the back, then possibly under the cook top. It is somewhere on your oven, sometimes the hard part is locating it. If you can find it, look closely and you'll see the wiring color and location is labeled. 2.) If you can't locate the tech data sheet, can you post a good macro picture of the back of your new switch so we can see what you're dealing with.
Posted on Aug 11, 2007
SOURCE: frigidaire compact 30 elec. stove.
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Posted on Dec 04, 2008
  • 127 Answers
SOURCE: Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
The oven TOD
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Posted on Dec 23, 2008
  • 1214 Answers
SOURCE: LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Posted on Jan 24, 2009
What are the dimensions of a kenmore microwave with model number 565.66401690?
best bet is to take a tape measure and measure the width , the height and the depth, write down those measurements then go to an appliance shop and measure all those on display
Dec 09, 2015 | Kenmore Microwave Ovens
Heating poorly
You need your burner replacing, order on line, just goole your oven model, you will need your serial number, half price of buying from your gas fitter, mine was, it's a five minute job to fit for a gas safe plumber
Mar 26, 2014 | Rangemaster 110 (Gas) Kitchen Range
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
I need to find a User Manual for my DeLonghi Microwave Oven DMX30 - I hope someone can help me.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Sep 19, 2011 | Microwave Ovens
Where is the serial number located on stove?
If it is labeled like the other VGIC stoves, the serial number is on the left hand side of the burner box (stovetop). Remove the left side surface burner grates, burner bowl and grate supports.
I hope this helps.
Jul 22, 2010 | Viking VGIC485-6G Gas Kitchen Range
Toshiba tv Model number 22LV61ou Where is the serial number?
Normally, the serial number is on the back of the TV on the manufacture placard. It should TOSHIBA in big letters, model number under it, and the serial number should be below the model number. It might be SS# or SS:
Sep 09, 2009 | Toshiba Televison & Video
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
41 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
