Question about Philips Magnavox 51MP392H Rear Projection Television
Magnavox MDL 51mp3964h distorted and waved picutre
I have an older 51" magnavox. the left side of the screen looks waved and rainbow colors not aligned. it has a very distink "wrinkle" all up the left side and it has started to wave along the bottom now and up the left side.
I bought this tv used, don't really want to pay a bunch to fix it, but i sure can't replace it. so i thought i would see what you think.
  • 2 more comments
  • patricia
    patricia Sep 17, 2008
    there is a wave up the bottom and right side of the screen.. and double vision! 70's flash backs
  • patricia
    patricia Sep 18, 2008
    From what i have read that sounds like what i need to do. I will ask a friend to help me do this since he's an electrician. Do you know how i can find the right part before we start taking this tv apart? it's rather large and in a very confinded space.
  • vtorres1 Nov 29, 2008
    I have exactly the same problem!!! the pictures are out of focus and look waved, recently started to flicker .
    I'm not an expert> Is it worth it to send it to be repaired? or I should just dumped?
    Thank you
    Victor8torres@hotmail.com
  • Anonymous Apr 12, 2009
    Same TV and same problem. Is it fixable? Is it WORTH fixing?
    Scholar:
  • 33 Answers
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Posted on Nov 20, 2008
I can not see the bottom writing on the tv screen.
Posted on Nov 18, 2008
    Genius:
  • 1,139 Answers
Hello pkrocks
It looks like your convergence amplifiers have gone bad, this is a common problem. If your set uses the STK329-110 or STK329-xxx series of amplifier both of them will have to be replaced. There is a lot of information on fixya about how to do this yourself, but you have to be careful in removing and replacing the amplifiers and the associated bias resistors.
I hope this helps
Thank you,
Shuttle83
Posted on Sep 18, 2008
I have a 52 inch magnavox with rainbow colored distortion on the screen
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox tv
try degaussing the screen... if your tv doesnt have that option, here are some ways to achieve that http://www.wikihow.com/Degauss-a-Computer-Monitor
Jan 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
I have a 46" magnavox projection screen tv that has the red, blue, green colors on the left side of the screen when first turned on. After a few minutes of being on, the screen resumes to normal colors. ...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Philips 60PP9352 60" Rear Projection...
Lcd looks a red wave line it look like it's out
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Hitachi 51GWX20B 51" Rear Projection...
The left side of screen is blurry.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Sony KP-51WS510 51" Rear Projection...
Magnavox 51 mp392H, red is out, what can we do?
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Apr 11, 2010 | Philips Magnavox 51MP392H Rear Projection...
Wave & three colors
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
Apr 07, 2010 | Panasonic PT-51HX41 51" Rear Projection...
On left half of the screen [ KP51WS510 ], a redish shadow showing
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
My magnavox 51mp392h rear projection tv has a yellowish color on both the left and right side otherwise the picture looks fine. recently replaced the convergence chips, which fixed that problem
Its the CRT fluid.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
391 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
