Question about HP Computers & Internet
I have a HP Workstation XW 4000 and it needs a Power Supply. I need to know what power supply to but that isn't an HP or Compaq power supply.
  • a_lono Sep 18, 2008
    Thank you for your help! I appreciate the fact you got back to me really fast! you are SUPER!
    Sergeant:
  • 300 Answers
You can use any 250-Watt ATX Power Supply with Power Factor Correction.
Az.
Posted on Sep 16, 2008
  • Steven Brown Sep 18, 2008
    Thank YOU for using FixYa!
    Az.
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
Where and how to wire motherboard intel 775
You should be able to get the pin outs and connector specifications from the HP website for that workstation model. Go to the service manual and it will have detailed information on what you need.
May 20, 2014 | HP Workstation Xw4100 PC Desktop
I need a power supply model atx250w-12z
part number you need is KJ383AA, KJ383AAR
they have the dimensions that fit your computer please look for your self. Measure your power supply you have.
New PC Power Supply Upgrade for Compaq Presario SR5450F KJ383AA Computer
May 14, 2014 | HP Compaq Presario SR5450F Desktop PC
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
Dec 13, 2011 | HP Compaq d530c PC Desktop
My lap top r 4000 light up and fan works but no display could this be the battery I replaced the power supply today
Hook it up to an external monitor, if that works. Might need a new Lcd display or at least an Inverter. May be a pinched wire near the hinge of the lcd display.
Doubt it's a batter problem, plug in the power supply , take out the battery and try.
Oct 16, 2009 | HP Compaq Presario R4000 Notebook
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
