Kodak EasyShare Z1275 Digital Camera
Problem for Kodak EasyShare Z1275 Digital Camera
KODAK Z1275
By CIENDIE on Sep 15, 2008
TURN ON CAMERA AND IT SHUTS BACK OFF
Comments:
Sep 17, 2008
- it shuts off as soon as you turn on and yes i have tryed the batteries the lens is stuck out also and wont go in even when i try turning on?
Same Problem
Dec 17, 2008
-   The camer is about 9 months old. at about 6 months it started turning off my it's self. then it would turn on and turn off real quick. It did that a few times then it would shut off leaving the lens out. Now it wont turn on at all. -   kkerr849
Dec 07, 2008
-   this camera sucks. It's so great when it work, but I have this same problem. Once I held the power key for a minute or so, and it suddenly started working again. Now it's doing the same thing and the power thing isn't working anymore. I've already sent it into Kodak once for this problem, but it's still happening -   tinkerbell75
Nov 14, 2008
-   I have the same problems,send the camera to kodak and get it back whit comment:use new batteries.
Why doesn`t kodak replace the camera?-   hans28
Nov 10, 2008
-   I have the same problem, lens is stuck out will shut off. I contacted kodak tech support, they said get new NI-MH rechargable battries. I did this I get the same results. Thanks for any help-   reddfoxx
Oct 05, 2008
-   same prob: lens stuck out, wont turn on.-   cooldudeav
Solution #1
posted on Sep 15, 2008
Somewhat Helpful)
kevellen
Rank: Guru
Rating: 87%, 47 votes
This instant turning off is usually a sign that the batteries are more or less dead. The camera doesn't have enough juice to run through the start up sequence and shuts down before its fully booted up. It will usually sense the voltage drop on the battery as it trys to engage the motor to get the lens to come out
I know its a silly question but have you tried it with fresh batteries ?
Regards
Was this helpful?
Yes
No
Solution #2
posted on Oct 11, 2008
Somewhat Helpful)
Technosavy
Rank: Guru
Rating: 88%, 57 votes
Aside from a new set of batteries, the most common problem with these cameras is the lens mechanism sticking or broken. If you are able to get the camera to turn on long enough to extend the lens a little, gently pull the lens out while it is trying to power up but do not force it. Check around the lens to make sure it is free of any substance that could cause it to hang up. If the lens cannot retract or extend fully the camera will shut down.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jun 29, 2009
Very Helpful)
jrbuilt
Rank: Apprentice
Rating: 100%, 1 votes
Tap on the side of the camera (where the memory card is located) after pressing the power button will temporarily solve this problem. I haven't contacted Kodak yet, but like most manufacturers, nothing will be done to remedy the problem. It's probably why the camera was such a good deal when I bought it. I won't buy another Kodak camera again.
JR
Was this helpful?
Yes
No
Solution #4
posted on May 30, 2009
Very Helpful)
gjdurhamintl
Rank: Apprentice
Rating: 100%, 6 votes
I semi resolved the problem with my Kodak Z1275 with this suggestion; Step 1, making SURE the batteries are good. Then, position the camera with the lens pointed up or down (depending on stuck lens position, USE GRAVITY AS YOUR FRIEND) and gently tap on the lens just as you turn on/off the camera. You may have to do this several times before the camera will close the lens. From my research this camera has a faulty mechanism for the lens which causes the software to recognize a lens failure thus shutting down the camera. Poor designed lens mechanism! I now am using my camera again, but regularly have to remember to allow gravity to assist in lens opening (turning on) and lens closing (turning off) as well as occasionally giving it a light tap or in extreme cases lightly assisting the lens opening/closing. Hope that helps! Oh and I don't suggest buying another Kodak camera!
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Kodak EasyShare Z1275 Digital
Questions and Unsolved Problems for Kodak EasyShare Z1275 Digital
Do you recommend Kodak EasyShare Z1275 Digital Camera?
Answer
Answer
today I started taking pics of the cats I have up for adoption and had to replace the batteries that... (More)
Answer
My camera keeps shutting off after every pichure
Answer
drains batteries while turned off. Put in new batteries. Only took a few pictures. Next day... (More)
Answer
used the camera many times switching SD cards ,current sd card was full and switched to a new one... (More)
Answer
do these camras come with a chargebal battry
7 Other Users Have The Same Problem - Continued
Comment by ry00, posted on Oct 01, 2008
I have the same problem, lens slowly went out, stuck in the out position,camera will not turn on or off.
Comment by josephineba, posted on Sep 26, 2008
I get hardly any power out of regular or rechargable batteries. I am very disapointed with the camera
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in Colton, CA
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
