Gateway M350MVN stopped working
Power and Charge ights come on. Fans are working but nothing on LCD
  • rolfev Sep 17, 2008
    New ram tried. No dice I think it may be the inverter. Thanks for your answer.
I've had this problem with a Satellite A40-271. I tried new RAM and it works. Also, the old RAM caused problems on my ACER laptop, so it must be faulty.
I hope this helps you!
Posted on Sep 16, 2008
Gateway DX-4380 won't start up but the fans begin for 1-2 seconds than stop.
unplug pc, hold power button in for a few seconds, open case, remove cmos battery ( looks like a watch battery) put battery back, start pc. If that does not work then unplug all hardware (cd drives) and try again to see if maybe it is a drive. If nothing works then its a good chance that your motherboard is bad.
Aug 20, 2014 | Computers & Internet
Gateway 6823a laptop display (screen) not working
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 25, 2011 | Gateway Computers & Internet
Hello sir i have gateway model md2614u .when i charge my battry and when it aharged full screen seen black but it shows power by red ight and it give no response.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 29, 2009 | Gateway MD2614u Notebook
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Gateway FX400S Desktop overheats after about 10 min.
the processor is overheating because the heat sink is bad.
Jun 08, 2009 | Gateway FX400S PC Desktop
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Won't boot up, Fans are on non-stop
Open up the pc with power off. After cleaning with a blowing or sucking device, gently press on the connections and plug-in devices. Retry.
If no avail, the power supply or the motherboard may have bit the dust. U can get them repaired or replaced.... or save the HD and buy a another pc and add the old HD as a data disk.
May 11, 2008 | Gateway GT5056 PC Desktop
Gateway 450rog does not power on
Sounds like a voltage regulator. Have the system diagnosed at a repair shop. Sorry I know this isn't what you wanted to hear, but is probably the correct answer.
Jan 19, 2008 | Gateway 450ROG Notebook
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
