Question about Toshiba Satellite A105 Notebook
Screen flickers and goes stripey
Screen started to have some white lines across, that disappeared when I moved the screen. problem got worse as time went on, today the screen showed double images and computer did not react to mouse / pad. when finally I found a correct angle of the screen and fixed in place, the laptop went back to normal, and I backed all my stuff up quickly.
Could that be a problem with the connection between screen and whatever it's connected to inside? like a broken cable that shorts out and confuses the poor thing?
  • 68 Answers
YES THE PROBLEM IS WITH THE CONNECTION
Posted on Sep 15, 2008
Horizontal lines across tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sony Televison & Video
White line across screen
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
White lines on screen and flickering
I think this is the problem of LCD.if it is then u should go to nearest service center .
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
Sep 13, 2006 | LaCie Electron 19" CRT Monitor
Toshiba Satellite A105 Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
