Question about Ricoh Aficio 1018D Copier
Ricoh Aficio 1018 - Squeaky noise when it copies.
My office copier makes fine copies but it makes this "i'm about to die on you" squeak while making copies. Our company wants to sell it because we do not use it much and I'm elected to fix the noise. Any ideas? Can I oil something?
  • 1 more comment
  • amandafoth Sep 15, 2008
    Its not coming from any of the trays or the sheet feeder. The squeak continues until the fan cycles down and/or it goes into "sleep" mode after the copy job is finished. It starts as soon as the copy button is pushed and lasts about 15 seconds after the last copy. Hope that helps. Oh I believe that it is coming from the right side of the machine when you are facing it.
  • amandafoth Sep 16, 2008
    Thank you for your help. I was hoping that it was just needing a little lubricating. But, it helps us know how much to sell it for. Thank you for your assistance.
  • Tim Babcock
    Tim Babcock May 11, 2010
    It could be in a number of places. Do you have a way of narrowing it down?
  • Ricoh Master
  • 2,794 Answers
It could need a fan replacement. Possibly the bearing is going out on it causing the squealing noise
Posted on Sep 15, 2008
Functional problem sc 390 on ricoh photocopier, despite replacing drum, developer,blade,gears. after removing 9 copies it reads functional problem.
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Aug 17, 2011 | Ricoh Aficio 1018 Printer
My Ricoh Aficio printer 1018 is telling me to "load paper 8 1/2 * 11" on the screen whenever i try to print anything from any computer in the network because i am using RJ 45 instead of normal...
Make sure you have 8.5" x 11" paper loaded into at least one of the paper trays, and make sure it's loaded in the same orientation as the page you are trying to print. Also check to be sure the copier is set to recognize 8.5" x 11" paper -- it may be set for a different size. On the main Copy screen, if you select the paper tray, does it show 8.5" x 11"?
Feb 03, 2011 | Ricoh Aficio 1018 Printer
Horizontal streaks and smears across whole page. Still does this with lightest setting. Can't read copies at all. Model- ricoh aficio 1018
sounds like the recycling pipe is blocked or cleaning blade has worn out
You need to take the drum unit appart and vac out the recycling coil and clean the cleaning blade.
Nov 21, 2010 | Ricoh Aficio 1018D Copier
My copier ricoh aficio mp 2000 makes a continuous creaking like an broken or consumed gear. what's the problem?
MP2000s often have creaking and squeaking issues. Typically it's the brass bushings that ride on roller shafts, so if you can isolate it to an area and clean and lube the bushings, you might be able to fix the noise.
Aug 12, 2010 | Ricoh Aficio MP 2000 Black and White...
Aficio 1018 cod.922
tengo una aficio 1018 me sale el codigo sc 922 que puedo hacer de antemano les agradezco
Apr 02, 2010 | Ricoh Aficio 1018 Printer
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
I NEED Ricoh Aficio 1018 Printer/COPIER AND SCANNER DRIVER
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x1015_18/x1015_18en.htm
There you go M8!
Just selcet your OS and download the files you need
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 15, 2008 | Ricoh Aficio 1018 Printer
Ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
Aug 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
645 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
