Cant connect to the internet it says that theres limited or no connection for my dwl-g520
    President:
  • 2,961 Answers
If you have security enabled then the passkey you typed is wrong, or you have told windows to repair the connection, this is the wrong thing to do as it changes the ip address, go to your network connections in control panel of whichever connection you are using go to the properties>TCP/IP laine>properties, then click the obtain an ip address automatically button and ok.
Close window, restart pc if necassary and try again.
Posted on Sep 15, 2008
Linux driver
Try getting connected to internet using wire or your cell phone internet and upgrade your kernel to 8.1 or higher !
Jul 31, 2012 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
I'm having issues with the internet ever since my son added a password to the wireless connection. I can sign on after about 5 or 6 times trying different methods. Once I sign on... I'm having issues...
Most routers will 'factory reset' if you hold the reset button for 10-15 seconds
If you are on DSL you risk losing internet connection if the router is handling the PPPOE login. The way to tell usually, is that the DSL modem will have an 'internet' light lit up along with the power, dsl, ethernet indicator lights. If the internet light is NOT illuminated on your modem when you get online, don't reset the router until you are sure what your PPPOE login credentials are
If you are on Cable, this won't be a problem at all
Jan 15, 2011 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
I need drivers
HI,
I need driver for D-LINK AIR PLUS XTREME G dwl-G520
H/W Ver :B4
F/W Ver:4.31
OS : WINDOWS XP.
Regards,
Shibu
Dec 25, 2010 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
Sharing internet from dlink 510g to linksys wap54g AP
yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
May 14, 2009 | D-Link High-Speed 802.11g Wireless PCI...
Cant get internet on both computers using router
When did the router stop working?
Have you tried a new cable between the router and the modem?
Since the status light is off on the router, that tells me that there is no communication between the router and modem. Is it possible that the router was reset by accident? Resetting it will put all settings to default. If it has been reset then you need to sign on to the router to setup the communication again to your modem. Typically this is done via the IP address.
I can walk you through those steps if that is the case. Try supplying a different cable though between the router and modem. Power off both of them, power on the modem and then power on the router....then try to connect to the Internet.
Mar 26, 2009 | D-Link DI-624 / DWL-G520 Kit...
D-link airplus g dwl-g520
what is an acceptable signal strength. I'm running between 50 and 60 percent
Jan 09, 2009 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
Windows SP2 and D-Link Airplus xtreme G DWL-G520
You don't state which version of Windows. That may help you get an answer.
Aug 05, 2017 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
Driver
You may download the latest driver from D-Link's web site:
http://support.dlink.com/downloads/
Then, follow the Quick Install guide you will also find there and you should be all set!
Feb 16, 2008 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
D-Link AirPlus Xtreme G DWL G520 channels proplems
I'm assuming you're in USA. The FCC may be limiting the frequency range that the card can use.  Check out drivers for other locations to see if that helps.  Also see if you have current drivers.
Oct 14, 2007 | D-Link AirPlus Xtreme G DWL G520 802.11g/b...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
