Question about Candy 24 in. CD622 Free-standing Dishwasher
Program on our Candy CD 622 Aquaviva Dishwasher is broken
We have the above item, when we turn it on it starts off, but then gets stuck on the first cycle and does not move on. Stays on first cycle for hours, until we turn it off.
Water is not being taken in on our candy Aquaviva CD 623 dishwasher
First check and see if there is plenty of water coming into the machine by examining the fill hose inself.
You likely will have to disconnect that hose, not at the machine end, the sink end.
Then, find a way to test the wires to the fill valve, should likely be 110 volts when the machine starts, allowing the fill valve to open.
A volt-ohm meter will tell you, set it to over 110 volts on the A.C. setting.
If no power to the fill valve, you may be facing a new timer.
Be blessed.
Jan 24, 2013 | Candy 24 in. CD623 Free-standing...
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
HI THERE I have a candy aquaviva 800 washing machine and it seems to not want to drain all of a sudden, i have taken out the hose at the back and given a good wiggle and sat with it in a bucket while
Your drain pump is dead. Have a serviceman replace the pump. How old is the unit? If it's old enough that it has the old belt-driven style, have them check to see if the belt is stretched or broken.
Apr 30, 2012 | Washing Machines
I need the operating instructions for a candy aquaviva cd623 dishwasher. Can anyone help with a pdf version I can download?
I am sorry to hear that you have problems with a candy dishwasher. I have had two or three pieces they just died of old age.
But seriously on line there is this manualsonline.com
You will most certainly find your candy manual there for downloading free.
Goodluck
kolbrun
Mar 24, 2012 | Candy 24 in. CD623 Free-standing...
Candy aquaviva plumbing
NO if it has two inlets then both are used buy a connector to connect both hoses together any diy shop will supply
Dec 20, 2009 | Washing Machines
Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
How to use the dryer of my Candy Aquaviva 1300 please?
wahing machine works great but a cant work out how to use dryer
Feb 21, 2008 | Candy AQ130 Front Load Washer
CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Jan 22, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy aquaviva 1000 es
Are you sure that this not is the cooldown phase of the mainwash? Most frontloaders have this feature.
Nov 28, 2007 | Candy AQUA1000T Front Load
Candy 24 in. CD622 Free-standing Dishwasher Logo
234 people viewed this question
Top Candy Dishwashers Experts
Charles T Nevin
Charles T Nevin
 Evgeniy_Getz
Evgeniy_Getz
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
