Question about Lexmark Office Equipment & Supplies
LEXMARK Z645 CORRECTLY INSTALLED NEW BLACK CARTRIDGE AND NOW GET GOOD PRINT FOR THE FIRST 2-3 LINES AND THE REMAINDER FADE OUT OR GET CUT IN HALF.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
There are a couple of suggestions here. I have searched and searched regarding this issue, which I originally thought was very unusual, but I actually have found an awful lot of postings regarding exactly this problem with Lexmark printers. Unfortunately, there aren't many with solutions... Additionally, for some reason, this is about the fifth solution I have posted that disappeared, so I am hoping this makes it to you!
Most of the time when blank pages are involved, there is an issue either with the software utilized (perhaps even margin-related) to produce the print, or a new machine is involved. As I don't have that information in your case, I will assume that your working environment has not changed. Please advise.
As unbelievable as this may seem, there are numerous reported instances where, even though the user had done this prior to seeking assistance, uninstalling and reinstalling a driver solved the issue (even prior to Vista). Are you using Vista? If so, please reference the following regarding a driver issue. You may or may not feel this applies to you, but if you are on Vista it wouldn't hurt to try, so long as you have the original driver...http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:548:0:0&docid=ENUS27756.
There is occasionally a problem created by the firewall in place on the host PC, as if the printer needs to communicate and its processes are not permitted exceptions to the firewall, it could affect printing. If you are using a Firewall (MS or otherwise), make sure all Lexmark processes/functions are listed as exceptions. The Z645 is included in the official Lexmark list of printers affected by this issue. (In other words, even if it is not related to this particular problem, we could at least prevent one from occurring in the future.) The reference is here: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:548:0:0&docid=ENUS26208.
Now for a couple of questions, in case we haven't hit upon a solution yet, as sometimes a well-placed question can help you hit upon the answer! Has there been any change whatsoever in the working setup - either in the PC or the printer - other than simply replacing the cartridge? (This could be drivers, OS, updates, changing PCs or locations, or even something so simple as a change of the typical type of paper used.) How old is the printer, and did the cartridge install as it always has before (as relevant)? Did you replace the cartridge with a new, Lexmark branded cartridge, or did you refill or use some other type of reused cartridge? Following replacement, did you align the print cartridges and/or print a test page?
If you use Parental Controls within your internet security package, this could be causing a printing issue, as this has just recently been discovered. Further, there are certain instances when the printers successfully print only when reconnecting the USB cable following each print job. If this potentially solves this issue, see http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:548:0:0&framed=&docid=ENUS30018&relevance=1. Finally, I would suggest that you check the Device Manager for any possible errors or conflicts that may be demonstrated there. For a screenshot of the typically appropriate listing, see http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=189:1:0:548:0:0&framed=&docid=ENUS24562&relevance=1. The latest driver for the Z645 can be downloaded from: http://downloads.lexmark.com/perl/downloads/downloads.cgi.
I came across one helpful hint - whether it will work or not, I don't know. This user fixed the black printing problem (which is very common with Lexmark apparently) by putting a piece of foam tape with adhesive on the front of the black ink cartridge. This helps to maintain contact between the cartridge and electrical terminals in back of the cartridge, which had become loose from wear.
Though it won't fix your print issue, perhaps it will help to know you are not alone. There are MANY folks out there with the same exact problem - and it is not related to the model or the cartridge, even laser vs. inkjet, it simply seems to be a Lexmark problem...
There was another suggestion that the copper filament on the cartridge contacts may have a bad grid line to the contact point. I am not certain of this, but it is stated that repairing this particular problem would cost more than simply purchasing another printer (of a different brand). And one more that seems possible. Set the contacts of the cartridge on a paper towel soaked with hot water for about 5 minutes, and yet another suggests cleaning contacts with alcohol. This is supposed to "loosen up" the "goop" (very technical term:-) in order to allow the cartridge to release the ink. If you desire to spend a great deal of time reading about issues just like this on Lexmark printers, try out www.fixyourownprinter.com.
Just to finish this up, hopefully with a bit of a smile, one of the posters on that page indicated that Lexmark had advised her to turn the printer upside down and shake it for about a minute. She did and a piece fell out, and it then worked fine. One response to her post, congratulating her, stated, "After you have finished shaking the thing, and it still doesn't print, take it outside, get an 8 pound sledgehammer and let her rip!" Then, here is another post that followed: "Hey I think I've solved the Lexmark problem! I live in England where we are geniuses in such issues. The printer is sensitive to barometric pressure, so I took it up to the roof, turned it upside down and shook it as recommended. Then I threw it off, and it worked great on the way down for a millisecond! Now how to prolong that moment???"
If nothing else, it never hurts to smile! Best of luck. Please let me know how it turns out.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 17, 2008
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
The Lexmark Z645 will only print blue, yellow and black
Hello. The nozzles of the color cartridge may need cleaning since it's doing the same thing on two different printers. Here's an article in the Lexmark website on how to properly clean the nozzles of the cartridge. Just click on this link: http://bit.ly/9wzuAL . If it still won't work, try your old color cartridge if you still have it and still working. If it works properly with the old cartridge, maybe you got a defective new cartridge. Hope this helps. Good luck!
Mar 23, 2010 | Lexmark Z645 InkJet Photo Printer
Bottom of line missing
First try and go to page setup under file and set your bottom and top margins to .25. is every bottom half line faded? If so then yes you might need a new ink cartridge.
Aug 12, 2009 | HP Deskjet 6980 InkJet Photo Printer
Won't Print
I also have a Z645 and have had it now for almost a year...love it's performance but now all of a sudden it only prints certain things...duh! I don't know if any of you that have problems went to the sdolution center for Lexmark but on there ...there an upgrade to your printer, which is not is a section that says you MAY need to install an upgrade which sometimes corrects the problem UNLESS of course you do as I do with my "other" lexmark and they tell you that there no longer is any updates so in that case you are S.O.L....basically you need to buy a new printer......I am gonna call tech support tomorrow for my problem but getting the upgrade MAY help you others....good luck!
Jun 14, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Printer Problem
you should go to your LEXMARK solutions center either on your desktop or in your start menue and open the maintenance program and run the alignment. select the best arrows and enter them where indicated. this should help clear up your problem with a new cartridge
Oct 08, 2007 | Lexmark Z645 InkJet Photo Printer
248 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
