Question about BenQ FP737S-D 17" LCD Monitor
White screen Hi u left a solution conserning my benq lcd with a white screen conserning capacitors as i hav checked all caps on power board and can see no swelling or leacking are there any particular caps i should be looking at thanks
  • halek Sep 24, 2008
    H iv changed both caps and screens still showing white one improvment tho is when attached to my pc and turned on the screen stays on as if working but as i said still just white
    Brigadier General:
  • 5,158 Answers
I believe they are two 1000uf 16 volt... there are two side by side and they are tall.
Robert
Posted on Sep 15, 2008
2600, if left off for a day,and when turned on, the screen is blank. only shows the frequency when it is warmed up but still does not key up or receive on any of the frequency displayed.when mic is press,...
White Glue needs to be cleaned off the circuit board. Common issue with these radios. Check for swelled or leaky capacitors. A radio of this age could use new caps anyhow.
Oct 24, 2013 | Radio Communications
Hi, my LCD Polaroid FLM-3701 went through a power outage and now doesn't get power any more. The power led doesn't show any light. I saw a capacitor repair kit available, and four 680 uF capac
The power supply fuse should be next the the ac input plug on the power supply. It should be a long cylinder type fuse, probably a T6.3AH/250V. You will want to replace those caps ASAP
Nov 05, 2012 | Polaroid FLM-3701 Television
I have fp567s monitor\r\nit often goes silver while starting and it needs monitor off button to be pressed (sometimes twice/thrice) for windows / boot screen to come alive i have re-installed the driver...
The silver hwite/grey screen means that the LCD panel is not getting the signals, 5vdc from the logic board. Try reseating the connections between the logic board and the LCD panel first.
Also check the power supply caps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Dec 13, 2010 | BenQ FP567s 15" LCD Monitor
Wont turn on
The problem usually is from low quality or defective "capacitors" on the main circuit board. There are two capacitors in particular on the main board that causes problems with these tv's. You can check for swelled up capacitors or burn marks on the circuit board. You can also purchase an analog tester or ohmmeter and test the capacitors.
If for some reason these caps test to be ok, then test the power inverter.
May 13, 2010 | Philips 37MF231D 37 in. LCD Television
Vizio vw42lhdtv10a 42" vizio will not turn on the vizio light is orange when tv not on and white when tv is on it turns white but i get no video or audio the screen doesnt change like it even wants to come...
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Mar 16, 2010 | Vizio VW42LF 42 in. LCD HDTV
TV wont turn on at all. I have read alot of forum posts about the capacitors. I took off back of TV and nothing appears to be out of order with capacitors or anything in power supply. I am not gettting...
I had the same problem. The power supply had a bad capacitor on the 5.3V output. The value of the cap is 2200uF / 10V. The top of the cap was swelled. With the cap changed the TV now turns on again. I hope this helps.
Jan 03, 2010 | Samsung LN32A330 32 in. LCD TV
Screen shuts down after 5 seconds
check the cables. If they are OK, it may be the power supply inside the screen. In some cases it is the capacitor that blows or swells/leaked which indicated it has gone bad.
Dec 04, 2009 | BenQ FP91G+ 19" LCD Monitor
White screen
dreaded capacitor issue. benq's were famous for it. if you are handy with disassembly and careful you can take it apart and do it yourself. look for any capacitors with rounded tops. i fixed one ... the part is only two dollars or so but it's a good feeling to know you fixed it instead of tossing it.
Robert
Aug 28, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq lcd Displays only white
Most often the all white screen is the result of a missing voltage to the LCD panel. We usually find an open fuse on the panel circuit board. Unfortunately replacing the fuse does not usually fix the problem.
Mike
Mar 02, 2008 | Computers & Internet
Benq fp737 17
How old are the monitors?
Normally backlights last at least 30,000hrs of working.
Normally problems on Inverter board transistors near yellow inverter transformers.
Samir
Nov 28, 2007 | BenQ FP731 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
223 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
