Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
253.26082101 I have a upright fz the model is 253.26082101 the control panel is reading a ec code and the alarm is going off.The fz is not cooling, and i notice that side panel is hot on both sides.thanks
  • Nelson Correa Mar 16, 2009
    I’m working on a Kenmore Elite mod.# 253.26082101.I'm have a similar problem as mention above except that the unit is cooling. I get a CE code and when I reset it stops beeping for a few minuets and then starts back up, which you could imagine it’s every annoying. I have replaced the battery. As mentioned it could be two things a bad board or a wire in the door. If the unit is working would that suggest another problem? I noticed that there is frost building up on a section of the door frame do to leak in the gasket, not sure if that is relevant.
    Thanks
    I’m working on a Kenmore Elite mod.# 253.26082101.I'm have a similar problem as mention above except that the unit is cooling. I get a CE code and when I reset it stops beeping for a few minuets, which you could imagine it’s every annoying. I have replaced the battery. As mentioned it could be two things a bad board or a wire in the door. If the unit is working would that suggest another problem? I noticed that there is frost building up on a section of the door frame do to leak in the gasket, not sure if that is relevant.
    Thanks
  • 120 Answers
The hot thing is normal be alarm when is not hot the condenser coils run on side of walls so is normal the ec means the board under the unit is not comunicating with the display on door it means error comunicating 2 things could be wrong 1 the board is bad need to be repl 2 there is a broken wire inside door. lastime i fix this i order both door and board but i tried the board first and it work so take a chance unles you have any type of warranty then call a tech
Posted on Oct 16, 2008
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Control panel is reading EC but numerical code...temperature reading is erratic as well. I turned the unit off and waited for 5 minutes and then turned it back on. I don't hear the unit running and EC is...
This is you electronic control board that is going out. You should probably repalce it as soon as possibel to prevent further parts from going out on your Sub Zero.
We are Sub Zero Parts Suppliers and will be happy to get this board out to you asap if you will contact us.
We hope this solves your problem and we look forward to being able to assist you with other appliance issues.
Nov 05, 2009 | Sub-Zero 685/S Stainless Steel Side by...
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I need to have a driver to detect my ECS GAYN20500595 to connect to the internet. What should i do?
go to start/settings/control panel/
when panel is open go to system/device drivers check modem does not have yellow mark on it.
If it does you will need to identify type and model of modem use friend to go on internet to find drivers
if it is clear go to modem in control panel right click/properties
when in modem panel go to diagnostics query modem
if it find modem then you need to set up internet connection from your provider
Jul 11, 2008 | ECS RS400-A (V1.0) Motherboard
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
258 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
