Question about Gaggia Baby Espresso Machine
Gaggia blew a fuse
When I switched on the machine it blew a fuse. This was replaced with a new fuse but still doesn't work.
Please can you help.
Thanks
Lisa
lisao14@hotmail.co.uk
  • 446 Answers
Ensure that you have replaced w the same rating of fuse, amp and voltage
also check for a possible broken part or wiring problem that could cause a short circuit
cheers
Posted on Sep 15, 2008
Gaggia syncrony compact will not switch on
I have had this problem. The main switch on the machine burned over and I had to take it to a maintenance to put a new on. I do not know if there is a fuse on the machine. It was not in my case anyway.
May 28, 2014 | Gaggia Syncrony Compact Coffee...
Gaggia Titanium Espresso Machine I have a Gaggia titanium espresso machine. Worked great until now, just stopped working. I turn the power witch on button and nothing turns on. I thought it could be a...
I had a similar problem and it was fixed by re-setting the two thermal breakers attached to the main boiler (you need to disassemble the machine to reach them)
Nov 07, 2013 | Coffee Makers & Espresso Machines
My Cerwin vega xls 15s doesn`t work!
Blown circuit. The question is; was it the power supply that blew out or was it the amp? check for fuses and see if they are ok. If they are not, replace them. IF they are then you are going to have to get new amp and or power supply.
Apr 26, 2013 | Cerwin Vega Audio Players & Recorders
My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 1003380 Accademia Espresso Machine
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
Replacement for Gaggia Carezza ON switch?
It is a standard switch, so you can repalce it, as long as you know what you are doing
Aug 19, 2012 | Gaggia Carezza Espresso Machine
Hit the bulb and bulb blew Is there a fuse? new bulb doesn't work either
Have you checked power to the lamp from the switch? Wiggle the switch a few times and see if you get a flicker
May 15, 2012 | Washing Machines
The machine has just stopped working, none of the buttons work. Tried switching on and off ....help please
sound like you blew a fuse. There is a little fuse box next to the on/off switch. You can buy new fuses at espressozone.com. Hope that helps!
Jun 26, 2011 | Lavazza Espresso Point Capsule Machine
'on' switch on Gaggia Carezza not working
Usually it is the switch itself that has failed. Order the switch from your appliance repair/supply business and replace the item in the machine. A lot of these switches have plastic 'ears' that need to be pressed in to release the old part and the wire connections are usually 'push-on'. Some that are held on by a formed metal clip usually require breakage of the clip to release the part and the new switch should have a replacement clip. Hope this helps!
Feb 14, 2010 | Gaggia Carezza Espresso Machine
Gaggia Baby Espresso Machine Logo
269 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
