Question about Black & Decker String Trimmer Cordless 12" 18V
How do I get my Black and Decker 12"bump feed trimmer/edger out of the groom position and into the edge position? My boyfriend misplaced the instructions to our new edger and I can't figure it out.
The handle/shaft is in two parts. By grasping the upper part of the shaft with one hand, and the lower part with the other, you can move the two sections slightly apart, then twist to turn the trimming end 180-degrees.
Posted on Oct 03, 2008
I have a cst1000 cordless trimmer. The recharging unit has failed. Do you sell a replacement that has the red and green lights indicating charging or charged?
Try this:
http://cgi.ebay.com/NEW-B-D-12V-VOLT-CST1000-Cordless-Grass-Trimmer-Charger-/200504468177?pt=LH_DefaultDomain_0&hash=item2eaeff62d1
If this has been helpful, please leave positive feedback. Thanks!
May 02, 2011 | Black & Decker Cst2000 12 - Volt Cordless...
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
Aug 20, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Spool is stuck
Have you tried using vise grips to get it off. Next time put neverseize on it.
Jul 18, 2009 | Craftsman 25cc Gas Line Trimmer
Auto feed will not work
I think your problem is the little plastic ( white ) lever ( part# 598435-00 ) on the inside of the housing that holds the spool. Mine was working fine and then it just stopped feeding line altogether. I would order a couple (3-4) so you have them in stock. Looks like a part that will wear out fast. I wish they still sold a bump type weed eater. Hope that helps.
May 28, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker String Trimmer Cordless 12" 18V Logo
95 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
