Question about Zenith C27A24T 27" TV
27" Zenith Television
TV does not work with COAX connection or using RCA connections. Any suggestions on this?
    Problem Solver:
  • 14 Answers
Assuming the picture tube lights up and you have snow when selecting the tuner function, I would first hook up a working VCR with a good tape and play it while the set is on channel 3 (if that is what your VCR is set to). If no sound or picture is displayed while the tape is playing,it could indicate a defective tuner. If you don't even get snow with no antenna connected (unless your set is designed to go to a blue screen with no signal present) then you could have a problem in the video processing circuits which would explain no picture with the RCA connections as well. This would probably make the set beyone economical repair.
Posted on Oct 23, 2008
Indoor antenna, connected to new converter box, connected to 1999 Zenith Combo TV. But all I get on the TV screen is Aux in the upper right-hand corner.
How do you have it hooked up, by coax, or RCA jacks! If coax Put TV on 3 or 4 if RCA Yellow, red, white jacks! ,make sure the yellow is in video in to TV and video out on box! both the box and TV jacks are color coded just match them up! but if You have in and out jacks on the TV, like I said make sure the yellow plug from box goes to to TV video in! One last thing, The TV could have more then one aux plugins, make sure TV is set to right one with your remote! Good Luck! Regards!
Jul 14, 2017 | Zenith Televison & Video
Zenith PV4663RK Rear Projection TV - Manufactured - Mar. 1995
Are you connected to cable TV using a digital receiver? If so, your TV can only get the signal for one channel - the one you're tuned into on your receiver. A workaround is to connect the coax cable TV cable directly to your TV, as well as connecting your receiver to your TV. This will allow you to be able to change the channel on your receiver and be able to change the channel on your TV to one of the analog channels you can tune into by connecting the coax cable directly to the TV.
Jan 09, 2008 | Zenith IQB50M90W 50" Rear Projection...
Tv will not stay on but if u turn it on,green light comes on and you hear tv click on but goes back off....
how are you connecting your tv to view programing? the cable/cables that connect from your receiver to your tv. are you using a coax cable? are you using rca? are you using hdmi? the first pic is a coax cable, the second pic is a rca cable and the third is hdmi.
Nov 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the cable connection on my tv
There are usually two types of cables that connect to your tv-- coax and RCA. Cable usually uses the coax style, but some modern tvs don't have a coaxial input, which means they probably have RCA jacks. Therefore, you will probably have to find an RF modulator or the like that has a coax cable "Cable" input and RCA (yellow, white, and red plugs) output. These should be able to connect your tv to cable. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Protron PLTV-32 Television
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
Mar 02, 2009 | Daewoo DV-T47N VCR
The coax cable connection on the back of the tv
Absolutely if you have additional inputs to the tv. You solved the problem yourself.
Have a great day and rember you have to find the proper input that you connect to to see image.
Jul 28, 2008 | Zenith B27A11Z 27" TV
RCA 27"
I suggest you check your Direct TV box. It may be off frequency. Stargazer
Jan 05, 2007 | RCA 27F650T 27" TV
You will be able to connect your vcr as long the tv you are buying has a built in tunner tehn you will connect it through the coax cable ant-a or ant b everthing else will connect via rca / hdmi / rgb / S-video good luck
Nov 07, 2006 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
How can I take advantage of digital cable?
No digital sound comes from Digital Coax or Optical and in order to utilize a digital signal u need HDMI or Component although component wont be truly digital. Try running everything to the TV then the sound out of the TV into the sound system. If its a high def source like high def cable box then use the optical conection on the back of the aquos and plug than into your surround system. if ur system doesnt support Optical or digital coax then you need an updated surround system. If i misunderstood your question im sorry. If u live in CT though stop by Circuit city in North haven. either myself, Dave, or my associate Justin should be able to help you out. and dont worry we're not on commission or anything.
Dec 17, 2005 | Zenith XBS344 System
Zenith C27A24T 27" TV Logo
75 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
