Question about Ovens
GE wall oven
Thanks to your help I fixed the F7 with a business card. Now the oven doesn't heat past 282 and it takes forever to get there. I cleaned the ribbon contact. What's next?
  • Den3 Sep 17, 2008
    Hi Powerman,
    Both elements are working. When I first push the bake button it shows 100 degrees (same as before), but it's always been slow to heat up, and now it's extremely slow. It will take up to 20 - 30 (or more) minutes to reach 350 degrees. I wouldn't know how to switch to celcius.
    An expert whose answer gotĀ voted for 100 times.
  • 68 Answers
Hi Den3,
Are you sure that you have not inadvertently switched to the Celsius temperature mode? A temperature of 282 degrees C corresponds to 540 degrees F.
I doubt that it is the heating element. They either fail by short circuiting or by opening up completely.
Posted on Sep 17, 2008
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
JKP18 WALL OVEN IS A PIECE OF JUNK    Go to the above link.  I will fix it.
Aug 17, 2008 | GE Profile JTP18 Electric Single Oven
GE profile light comes on by itself and then get f7, this site will give you the code and if your mechanically inclined you can do it your self ,but if the warranty isnt exspensive you might want that,but it is the keypad
Jul 07, 2008 | GE Profile JT912 Electric Single Oven
F7 error
I am assuming you have two sections to the ribbon cable and a plastic touch panel. Try cleaning the area between ribbons in the area of the slot in the touch panel. Use alcohol and a Q tip. Let it dry. Try forcing the business card further down into between the ribbon cables. If you have a metal touch panel, you need to apply insulation between the ribbon cable and the edge of the slot. Refer to my instructions at the following link:
If this doesn't help, you have a short in the touchpanel at some other location and my fix can't reach it. You will need a need touchpanel.
Jul 05, 2008 | GE Profile JTP18 Electric Single Oven
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
Ge wall oven display says F7
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at
May 29, 2007 | GE JKP30WMWW 27" Built-in Single Electric...
F7 error code
Hi Kathryn, I believe that I have already sent you my solution via another route. Hope you received it. Basicaly for anyone else with this problem, it is caused by a short circuit envolving the ribbon cable which connects the touchpanel to the electronic control. The solution varies slightly depending on whether you have a metal or plastic touch panel. If you have a plastic touch panel,you need to add some extra insulation between the two pieces of ribbon cable in the slot where it exits the touchpanel. You need to slip it down as far into the slot as it will go. A piece of paper, a piece of file card, a thin piece of mylar will all work just fine. If you have a metal touchpanel, you need to insulate the edges of the slot as well with paper or mylar. Insulate both edges. If you don't have two sections to the ribbon cable, obviously you can't put insulation between the sections. If you have a plastic touch panel and only one section to the ribbon, you are out of luck. There is nothing you can do except to purchase a new touch panel. Cleaning the contacts is a myth. It doesn't help. Hope this helps. Please let me know your results. Contact me at Regards, Charlie
May 08, 2007 | GE Profile JT910SASS Electric Single Oven
GE Profile Oven FTP18 - F7 Code
The F7 problem is usually caused by a short circuit between segments of the ribbon cable connecting the touchpanel to the ERC. Open the touch panel. Insert a slip of paper (yes paper) between the two segments of ribbon cable where it exits the slot in the touchpanel. Try to work the paper down as far as possible. A piece of file card may work better. See the attached photo. If you have a metal touch panel, also add slips of paper between the ribbon cable and the edges of the slot. I have shared my solution with over 795 folks with the F7 problem. Most report success. Cleaning the contacts is a myth. It is only a short time solution as when you move the cable you are temporarily disrupting the short circuit, but it will grow back. The short is caused by what is know a dendrite. It is a growth from the silver traces on the membrane switch conductors. If you want more technical information, contact me at The solution should work for all ovens made by GE including Kenmore as far back as 1998. Don't be concerned about putting paper in the top of the oven. GE places a set of instructions in the top of the oven. Many folks have replaced touchpanels only to have the problem return.
Oct 03, 2006 | GE Profile JTP18 Electric Single Oven
Ovens Logo
152 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
