Question about Minolta Office Equipment & Supplies
Minolta 3120 the drum is not being cleaned off and cannot figure how to get the toner unit out so I can get the drum unit out
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minolta Master
  • 1,362 Answers
Could be it has to be done in the service mode to "disengage" the DV from the drum. As I suspect if there is no lever to diengage it.
Posted on Sep 17, 2008
Model 600. Why is it dropping toner near transfer corona unit?
When is the last time the developer and drum where replaced? When the last time was a PM done? Very 250,000 copies a PM must be done? Which replaces the Corona Wires, Developer, Drum, Corona Grid, Web roller for fuser (Hot Part). Also during the PM the Tech should clean the toner out of the Waste Toner collection unit on the image unit. also clean the area around the drum and developer roller.
Oct 28, 2015 | Konica Minolta bizhub Office Equipment &...
How do I clean corona units on Minolta 1081 copier?
Gregory, First remove the drum unit. Then remove the Charge unit. located about the drum on the drum cartridge (Not Inside the Machine) Then remove scortron grid push the front in to release you then have access to the charge wire this model may have the Charge comb type be care the combs are sharp if they are wires be gentle and use a eraser to gentle clean the wires they are very thin. During the copy process the wire/comb applies a HV charge on the drum prior to the image from the mirrors being place on the drum before the paper arrives underneath the drum.
Jan 02, 2015 | Konica Minolta Minolta EP 1081 Laser...
My minolta 1083 is making black copies ,The drum is cover with toner .I can clean the drum off,& make 2 copy then it`s cover with toner again making black copys
you need to clean out the drum unit of waste toner than probably have to replace the cleaner blade.
Also check to see if there is a tension spring employed to add friction(since this is a phase - out model, I'm guessing there is), you might have to modify this spring to add tension to the cleaning blade support plate.
Feb 23, 2011 | Minolta EP1083 CS/PRO Copier
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
Konica minolta 2400w....lines verticle in all prints...what do i have to replace or clean to fix this problem
check its cartridge if lines are on the drum then replace the drum unit, if drum is clean then replace only the toner.
Apr 16, 2010 | Minolta magicolor 2400W Laser Printer
Yellow deposit
Remove the Yellow Drum unit, Check the drum for any toner. The drums should be clean and I believe a Green color. If you see any toner on the yellow unit replace the unit. Some models have a charge cleaner built into the image units, if that is the case with yours you will see a light blue knob on the front of the unit. Pull this knob in and out about 5 times to clean the units charger this may correct the problem without replacing the yellow image unit.
Mar 09, 2010 | Konica Minolta Magicolor 5670EN Color...
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
Refill toner konic minolta 1350w
hello
i just installed a new cartridge , but i still have vertical streaks on my sheets
do i need to get the toner clean , and what product do i use ?
thanks again for you time / help
Mar 19, 2008 | Konica Minolta PagePro 1350W Laser Printer
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Nov 05, 2007 | Minolta Office Equipment & Supplies
41 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
