Question about Boating
Suzuki dt2 i have a suzuki dt2 outboard ,it starts ok but when throttled down it cuts out,also at full throttle is runs erratically any ideas i thought maybe a fuel mixture -airscrew setting,.what ratio of petrol -oil.have been told its 100-1 but i think this is too high and may cause engine seizure, thanks Dave.
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
rburroak
  • 14 Answers
SOURCE: only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Posted on Jun 19, 2009
moretons
  • 155 Answers
SOURCE: mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Posted on Jul 25, 2009
SOURCE: 2007 FX Waverunner 1100, turning left the engine
First, I'd check the routing on your throttle cable. make sure that at left and right turn, it has slack and no tight spots. Assuming your fuel stystem is clean, that pretty much leaves a ground/short problem somewhere. The fact that it happens at left turn tells me it's in the wiring that routes through the controls- perhaps the kill switch wiring. Something somewhere has rubbed the insulation off the wiring, and it's being moved when you turn left, so it shorts against metal. This will be the same metal point that rubbed it raw.
A. Check the throttle cable routing. Move the bars back and forth, and watch for a tight spot.
B. Check your wirinig harness from the bars to the main wiring harness, and look for signs of rubbing or wear.
Posted on Aug 03, 2009
Suzuki jr80 takes too long for rpm to get back down to idle , after throttle is released. wasnt run for couple yrs. completely disassembled carb and cleaned. it starts 1-2kicks.not setting correctly?
Hi, Troy and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Lazy Slow Return to Idle or Erratically High Idle
2 Stroke suzuki JR80 tuning help
http://www.soemyanandarthetlwin.com/hwa/suzuki/suzuki-jr-80-service-manual.pdf
OEM parts for Suzuki
Suzuki DS80 and JR80 Motorcycle Cyclepedia Online Service Manual
Suzuki JR50 Owner Manual
May 25, 2017 | Suzuki Motorcycles
Starts up, then why does it cut out when going to full throttle?
possibly overheating try running slower which creates less heat
Oct 25, 2015 | Yamaha Tilt Trim Motor, 115-225 HP...
Please only marine mechanics reply I have posted a question about my 90 hp force outboard the warning sound starts sounding while running full throttle after about 15 minutes of running full throttle I can...
Is this motor used in salt water?
That warning buzzer on your motor is really only tied to the temperature. In order to triage sensor or overheat condition, I'd recommend an infrared thermometer to get a reading on the engine as the buzzer is sounding. There is a product that is like a glue stick which can be pressed against the engine which melts at a very specific temperature... not sure if it's around anymore as the remote thermometers are pretty inexpensive now. Is there good water flow out of the ports below the cowling on the back?
May 01, 2017 | Mercury Force Starter, , Sport Jet,...
My 96 suzuki quadrunner 250 and I thought my throttle cable was in a bind not in a bind idles fast when you turn right what is wrong
Possibly if moisture has got in and created rust then you have a problem. With the engine not running twist the throttle very slowly to full limit then let go the spring should snap the whole thing shut instantly. If this does not happen the cable is binding. Undo the cable at the twist grip end and get as much lube down it as possible a clamp type cable luber will help.
Dec 13, 2014 | 1997 Suzuki GSF 250 Bandit
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
I have a Suzuki 4 stroke 40 HP outboard motor that sputters while in full throttle. How can I fix this?
this sounds like the high idle circuit of carberetor has debri in the needle. I would consider cleaning carb and try again. If still continues then this would make me look at fuel pump. These 2 things are where you need to start.
Mar 22, 2012 | Boating
Hi i,ve got a cb900fz running very rich on cyls 2,3,4 the carbs appear to be standard i,ve recently fitted new air cut off valves float heights appear right but are plastic one piece units so non...
sound like the carbs need to be synced if throttle plates are fully closed at start it would cause a rich condition and no need for a choke becase there is very little air passing through mostly fuel if they are not eqaul there would be hesitation when opening throttles til about 1/4 throttle
Jan 30, 2010 | 2004 Suzuki GSX-R 1000
My 2003 yz250 runs full throttle as soon as it is started. Checked the obvious stuff - carb throttle....it started revving out of control intermitantly now its full time. Any ideas?
3 things... First twist the throttle rapidly and listen for the carb slide to move up and down,, ya should hear a clicking in the carb... if so slide ok.. Sure bout the throttle cable ? At grip ? When starting the bike takes alot of kicks to get started ? As if were flooded ?
Aug 29, 2009 | 2003 Yamaha YZ 250
Apr 27, 2009 | Boating
Boating Logo
431 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
