Question about Panasonic TH-42PD60U Television
Panasonic TH-42PD60U Wont come on..
TV went off while watching it..no surge, however A/C kicked on about same time so "brown out" possible.
I get 8 blinks on the power led.
Please help
Hello, I went to the Panasonic web site and it said driver sos3 (SS energy recovery circuit) on the SS board. call 1-800-211-7262
Posted on Feb 11, 2009
Panasonic plasma tv, TH-42PD60U Picture break up with sound. Ran a fan behind it to cool it off. Worked for a while, then stopped completely with the 8 blinking red light.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 08, 2016 | Panasonic TH-42PD60U Television
I turn on my Panasonic TH-42PD60U Television - red LED blinks and there is a clicking noise but TV doesn't turn on.
Panasonic plasmas are notorious for their power board problems.
I can't know which one of the few possibilities yours might have, but at the very least it is worth checking against the most common ones(s):
http://www.coppelltvrepair.com/p/54/repair-kit-for-panasonic-th-42px60u-panasonic-th-42px600u-and-panasonic-th-42pd60u
Read the listing, get a multimeter and check the described components for short or open (in case of a fuse) and if it matches then that's the problem and that's the solution.
For in-depth troubleshooting help consider using www.coppelltvrepair.com/diagnose - it's free to ask, but we may not always be able or willing to help and when we do we'll typically put a price on a consultation.
Sep 30, 2012 | Panasonic TH-42PD60U Television
PANASONIC TH-42PD60U will not power on/no power light/have already replace power supply
If your power supply is new try to check the power cord..If you have a volt meter or multimeter range in AC..check the voltage input of your power supply it should have 110v to 240 volts depends on your electrical supply in your outlet..
If no voltage replace the power cord..Hope it helps..
Mar 06, 2012 | Panasonic TH-42PD60U Television
I have a th-42pd60u and the screen is off and wont turn on. the red led light flashes 6 times
The Sc board or the D board has blown which is indicated by the 6 flashes of the led. You need to replace one or both
Mar 03, 2011 | Panasonic TH-42PD60U Television
I was watching tv and suddenly the picture went off.Now the red power light is flashing and I cannot get a picture.model panasonic viera th42pd60u
Tries tv unplug,replug it back like about an hour later,by for the tv resetting itself back for factory setting.Now tv should be working,if still have the same problems.The tv have power supply board problems and causes.That the board,where the power a/c cord plug into it.Tries website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 16, 2011 | Panasonic TH-42PD60U Television
Need Help.
Can you get the On-screen menu to come up using your remote?
Jan 07, 2010 | Panasonic TH-42PD60U Television
Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me. Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
Oct 03, 2009 | Panasonic TH-42PX60U Television
Panasonic Plasma no sound, can't change channel
Yes the control board would definitely be the offender here. But a word of caution. Oftenj when this board goes 2 other boards are also compromised and not always obvious at the time people think they can just swap the board out.
It went for a reason, not just old age. So it is better and cheaper in the long run to get a professional to check it out.
Also from a safety aspect, this is the High Tension area of the TV. Also be aware that radiation of the X type is in abundance at the rear of the tube. The TV must be grounded when opening ( but my advice is dont!) Let the professional do it
Sep 18, 2009 | Panasonic TH-42PD60U Television
Tv will not turn on
Had same problem, no turn on.
No blinks, by the way.
Checked fuses, everything is ok.
Had Panasonic tech check it, and he found that by disconnecting the DT (digital tuner) board, the system would "click".
He said $700 total to repair ($500 parts). I said no.
I got the TV to work, by unpluging and then pluging back the DT board WHILE POWER ON.
Now TV works, but if I turn the TV off I have to do the unplug plug sequence.
This is VERY DANGEROUS as there are high voltages in the TV, so I don't recommend it to anyone not trained.
My long term solution? Find a cheap DT board on ebay or WWW
Jan 19, 2008 | Panasonic TH-42PD60U Television
Televison & Video Logo
470 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
