Question about NEC Dterm DTP 16D-1 Corded Phone
Can't anwer the phone with just picking up handset
Also, the "answer" button doesn't lit on incoming call
Please help!
  • 149 Answers
You need to call your vendor out to program the phone. Something is missing in programming to allow you to just pick up the handset.
Posted on Nov 13, 2008
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me abigail@nkaditelecoms.co.za
An upgrade can be offered, with lower call rates.
Jun 13, 2017 | Lands Phones
I cannot answer the phone without pressing the incoming call button that is flashing. I want to be able to answer the phone just by picking up the phone.
From the phone, don't pick up the handset and press PROGRAM 99 then dial 22 and press STORE. Here's a problem. By default, that's what it's supposed to be and if it beeps twice when you press STORE, you didin't change it. Pick up the handset and drop it back down to exit programming.
In order to have incoming line preference, your phone has to be RINGING :-) So, if the first program didn't work, you need to see your system manager to program your phone to ring. Or find an installation manual on the internet.
Carl
May 20, 2011 | Panasonic KX T7220 Corded Phone
I have a 2 handset GE cordless 25932EE2. Both handsets work great individually, BUT when we answer an incoming call with one phone, we can't use both handsets at the same time (for the same call). In...
The problem may be due to both your handsets operating on the same channel. To fix, try pressing and releasing the "chan/delete" button on one of the headsets. This will move it to the next available channel.
Mar 08, 2011 | GE 25932 Cordless Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
How can I change a handset to automatically answer an incoming call when you pick it up
In most handsets in the phone settings menu u have an option called automatic answer.Once the option is enabled u would b able to answer calls automatically
Aug 06, 2009 | Lands Phones
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Anwering calls
Press the delete/transfer button on the bottom of the phone and both ther phones will beep than the other one can be picked up with out being cut off.
Mar 05, 2009 | Dual Maxus 5.8GHz Handset Cordless Phone
Can't answer direct line calls
This sounds like a programming issue on this telephone. There are 2 areas in programming that would cause this. If you have recently had a technician out to do some programming then it is possible that he made a mistake and needs to be called back to correct his mistake.
Nov 12, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Oct 17, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
164 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
