I just bought a Toshiba Satellite laptop. The manual says I should not
over charge the battery. So I have to unplug it when it's fully charged even
if I don't have to, and plug it back in when the battery is low. I figure
the battery would have to be recharged / discharged couple of times this way
each day. That can't be good, can it? I don't understand why it can not be
made to stop charging when the battery is fully charged. I have many devices
that will automatically stop charging when battery is fully charged. Is
there any other brand that does not require you unplug when the battery is
fully charged?
Thanks for any help!
ZR.
I have a dell and leave it in all the time no problems in two years
Was this solution helpful? Show your Appreciation by rating it:
by fully cycling it once or twice per day than you would by leaving it
plugged in with the battery fully charged most of the time.
generic safety warning about not overcharging the battery if, for
instance, you used some charger that wasn't designed for the battery.
I agree with the others above who claimed y
may well cost $200 to $250.
First, the battery can only sustain a limited number of charge-discharge
cycles. While the number varies, it's in the range of low to mid
hundreds (say
Post a New problem for Toshiba Satellite 1105 Series 14.1
Email this problem
Can you Help with these Monitors problems?
restore system using ctrl,alt...
