Question about Uniden Cordless Phone
No dial tone
I do not have a dial tone on the base unit nor on the 2 extension units. The phone was working yesterday. I've attempted to repair by unplugging base unit and removing and replacing all 3 battery units. Still nothing. Any suggestions?
  • 1 more comment
  • mrben517 Sep 29, 2008
    I'm presently experiencing the same issue. I unplugged the power and the phone line and plugged in another device and it worked. All I getr from the GE 25825 base is static. The phones will ring but because it will not produce a dial tone from the base the cann ot be answered.
  • Anonymous Oct 02, 2008
    same problem no dial tone can't make calls.
  • Diane Keene-Meadowcroft
    I have the same problem changed battery and unplugged not the problem
My base unit did the same.... power from the wall was out ... check GFI switch.
Posted on Sep 18, 2008
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
My Uniden TRU9485, all units (4 in all) get a dial tone, but will not dial out on TONE dialing. If I change it to PULSE, it works. These are about 1 year old and just noticed this today. Is it the phone or...
Ok, comming from a Cable Tel Technician, this is most likely your telephone service.
Contact your Telephone repair for them to reset your tel service (this will most likely be due to a digital service outage and will need to be repaired.)
An option is to try a cheap wired phone in the outlet experiencing the issues and attempt the problem again. if this rectifies the issue, remove the phone from the wall outllet(electrical) and wait a few moments and also remove the batteries for 30 seconds total.
If all the above does not fix this issue, attempt calling the manufacturer for a more abrupt powercycle method to reset the base unit (Transmitter)
Sep 02, 2009 | Uniden TRU9485 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Uniden Cordless Phone Logo
216 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
