Question about GE AJCQ08ACB Air Conditioner
Compresser is not turning on
The air condition is a ge model no. agm24dtm1 and the compreeser is not working
Check your capacitor
Posted on Sep 15, 2008
No engine compreesion
have a compression test done to confirm your suspicions. If the compression is low on some but better on others it may be valves . If the compression doesn't alter check the cam shaft is turning ( broken timing belt)
Mar 24, 2014 | 2010 Ford Fusion 2.5
No compreesion on 2000 gmc 4.3l
You need to check the mechanical timing of the cam and the crank. it appears that they are not correct. The valves are open when the pistons are compressing.
Dec 01, 2012 | 2000 GMC Jimmy
Sometimes it cranks real hard and wont start has a new battery but it seems like the compreesion release is mot pulling down how do I fix this?
Compression release for the rear cylinder was my problem.adjust the slack out of the rear cable and see if that doesn't solve the problem.it doesn't take much,and try not to over adjust.
Jun 26, 2012 | 2001 Suzuki VL 1500 Intruder LC
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
When i kick the kick goes down completly. I guess is their is no compression.It was working fine till yesterday and all of sudden compression is their an easy fix... The gear were hard to put ..but I...
actuly when we kicked either provide self piston gose up side. when piston goes upside it provide initiating power now spark gived it by the spark plug and there feul will burn properly. here problem is this your volve timing or volve get leackage tats why your compreesion system not working properly. so first of all you just chek out ur volve timing got it..??
May 09, 2010 | 2006 Enfield Bullet Machismo
Washer works okay on drivers side but is barely flowing on passenger side.
Try to take a SMALL WIRE and clean it out, or take the hose off, and try to clear it with compreesed air.
Dec 31, 2009 | 2001 GMC Yukon XL
Air conditioning compressor will not kick in,
If it is above 100PSI, you are over charged. Any thing under, should be normal to low. You probably need to get it checked by a professional to make sure it has the correct charge, and the compressor is getting power when the switch is turned on.
Jul 14, 2009 | 2003 Mitsubishi Lancer
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
My air condition is working but the fan is not turnig
fan has to turn for system to function properly turn off breaker see if fan turns if not bearings are shot if it does maybe fan motor bad or wiring issue! Good Luck!!!
Jun 24, 2009 | Goodman CKL36AR36 Air Conditioner
GE AJCQ08ACB Air Conditioner Logo
63 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
