Question about Jensen VM9020TS Car DVD Player
Amp to jensen uv8 hook up
I cannot figure out the 2 wires that go from the amp to the dvd player..1 is red and the other is blue or gray..what wires on the back of the dvd are used for ..theres so many..on 1 part theres sub woofers..front r..front l..rear r ..rear l....then another one is aux in 1..aux in out 1 out camera
To fix your problem cut the wire in half connect it to a ground and hot and there ya go it fixed my problem
Posted on Feb 19, 2011
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
Uv8 some seakers dont work in dvd/cd mode
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
No Audio on Jensen UV8
I just bought the uv8. Ist I must say i hate it, it was the worst purchase made. Amoungst others problems, your answer to solve no audio is this.
<<push mute button>> then volume up. you'll have sound. good luck
Jan 03, 2009 | Jensen VM9510 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Have no sound when the cd and dvd is played
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Oct 29, 2008 | Jensen VM9510 Car DVD Player
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9020TS Car DVD Player Logo
106 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
