Question about Venturer RTS2628 System
ONE FOR ALL REMOTE CONTROL
HOW CAN I CONNECT A URC7150 CONTROLLER TO A NEW VENTURA TV?
RCA TV Converter Box DTA800B1. Codes for roku tv
For a Cablevision cable Provider the remote controller Model Number is UR2-CBL-CV04 and its remote device unique codes for Roku TV become 031, 081. To get a Charter Cable Provider the remote control Model Number is usually UR4U-MDVR-CHD2 and its remote control codes for Roku TV be 11756, 11602. The user on find their respective remote controller code, have to activate their Roku account using enter Roku activate code to get started on streaming their recommended shows.
For a new Cox Communications Cable Provider the remote control Model Number is URC-8820-MOTO and its remote control codes for Roku TV be 1756, 2360. For the DirecTV Cable Provider the particular remote control Model Number will be RC65 and its remote control codes for Roku TV be 11756, 10818. For a Dish Network Cable provider the handheld remote control Model Number is 21.1 IR/UHF and its remote control codes for Roku TV be 535, 556.
The ONN Cable Supplier the remote control Type Number is ONA12AV058 in addition to its remote control rules for Roku TV are 3851, 3201. Once the consumers remote controller are programmed with the respective codes then the user also have to activate their Roku accounts using enter Roku activate code to start out enjoying their preferred streams.
Hope you find your own appropriate code for your cable providers. For any help on adding the RCA Roku TV codes call our technical support staff members through toll-free numbers +1-855-804-1313 or visit them at roku.com/link
Dec 16, 2014 | RCA (DTA800B1) Video Converter
Need code for universal control for a bush LCDS20TV007
We do not have these codes, just to many of them and they change constandly with each new device, the best thing to do is use the code search feature o fthe remote, check your user booklet for these instructions, very simple to do.
Feb 01, 2012 | Televison & Video
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
Lost instruction code for 'one for all' remote urc-3430
There are no codes for URC3300, but there is a Set Up Manual, if you would like a copy email me at capslock99@optusnet.com.au
May 05, 2009 | One For All URC-3300 Remote Control
Lost my manual for my urc22b controller
I need codes for remote unviersal 22b to control panasonic tv
Mar 23, 2009 | Televison & Video
Samsung TV remote control controls two Samsung TV in same room.
You cannot reprogram the samsung remotes. I just installed three samsung tv's on the same wall. I used a harmony 900 remote. It has a rf receiver with an IR blaster two IR emitters. You can designate each emitter to a specific device in the remote. I used the main remote IR for the main tv, The blaster for the a/v receiver,blue ray, ect. Then I used each of the emitters for a tv. I can control each of the tv's independently with no interference.
Mar 07, 2009 | Televison & Video
My wireless remote is not connected to my computer
Are you running the MCE version of XP and is it installed? Look for c:\Windows\eHome directory. If you find that directory, then you should have MCE installed and running. If not, you need to get and install the MCE version of XP. Then look here for further information to getting your remote to work with the MCE.
Help Installing a Remote Control in MCE
I hope this helps?
Feb 03, 2009 | ATI T550PRO TV TUNER PCI W/REMOTE...
Omnitech jumbo universal remote control and vizio hdtv
Here are the instructions for auto code search from the Omnitech manual:
Automatic Search
There is another way to set up your controller, that does not use the brand code lists. You can let your
controller search through all of its available codes automatically in order to set the connection to the
target device. To do this, follow these steps:
1.Turn on the target device.
2.Point the controller at the target device and press and hold the Code Search button for around 3
seconds, until the LED light stays red.
3.Next select the type of device the target unit is by using the Cable/TV/VCR/DVD/Sat Buttons (i.e. if
it is a TV that you are trying to control, press the TV button). The LED light should then blink once,
then stay red.
4.Press the On/Off button on the controller slowly and repeatedly until the device you are trying to
connect with turns off. (Note: the LED light will blink each time you press the On/Off button). When
this happens, press the ENTER button in order to store the code and the LED light will turn off.
Jan 02, 2008 | Big Button TV Universal Remote
Venturer RTS2628 System Logo
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
