Question about Microsoft Xbox 360 Console
Xbox 360 Ethernet Connection broken
I am pretty sure this a hardware problem.
I have tested a bridged network connection on two seperate systems. All hardware is the same except the 360 console. The working system connects to the internet and xbox live just fine, but the problem system hits a wall. When I run the 'Test Connection' on the problem system it stops at the first step saying its disabled.
Is this just a problem with a setting on the one system, or is it a hardware problem?
  • Brandon4048 Sep 18, 2008
    it happend to me too and when I pluged it to the back of my computer it worked fine<:(
  • Anonymous Jan 16, 2009
    Same its stupid what should i do?
  • 31 Answers
Sometimes you cant run you will need to adjust your network settings call 1-800 4 myxbox they can help
Posted on Sep 18, 2008
How to connect xbox360 to internet with laptop
Hello bernelltaylo,
This is a very simple procedure, but pay close attention.
First, here are the requirements to attempt this procedure.
_____________________
- An Ethernet Cable,
- Wireless Connected Laptop
- Bridged Connection Eligibility
_______________________
1. Get an Ethernet cable, they are commonly blue, or yellow.
2. Plug one end of the Ethernet cable into the back of your Xbox 360 console, and the other end of your Laptop.
3. Log onto your laptop, (assuming you're using Windows), and find the list of your wireless/wired connections.
4. You'll see something like, "Local Area Connection 2", and "Wireless Network Connection 3". Make sure you're already connected to the Wireless Network before continuing to the next step.
5. Highlight both the connections, and right click one of them. Click on, "Add a Bridge".
6. A process will start which will bridge the connections, enabling your laptop to work as a modem for your Xbox 360. This may take as long as anywhere between seconds, to minutes.
7. When it's done, do NOT remove the Ethernet cable, until your desire to disconnect from the internet on your Xbox 360.
______________________________________________________
Hope this helped, see ya' later. :)
Dec 02, 2012 | Microsoft Xbox 360 Console
How do i join and set up xbox live from my laptop to my xbox360 console using a ethernet cable/help
1) Connect your ethernet cable to your computer and xbox
2) On your PC, Go to network connections and right click on your wireless connection
3) Click the advanced tab on top
4) Go to Internet connection sharing and check the box, click OK
5) On your xbox, Go to your network settings
6) Edit settings and set everything to automatic
7) Test Connection
You must have your PC on at all times to connect to Xbox live this way.
If this setup doesnt work.
1) Go to Network connections
2) Select both your wireless connection and your LAN connection
3) Right click and bridge the connections
4) Same setup on Xbox as the previous instructions
5) Test Connection.
Apr 29, 2011 | Microsoft Xbox 360 Console
Trying to get Xbox live connected...
Follow these steps if you are trying to use a laptop :
1.
Make sure that your XBOX 360 is fully functional and your laptop is connected to the internet by means of a wireless card.
2.
Locate the Ethernet cord and connect it to both the computer and XBOX 360. Don't turn on the XBOX 360 yet.
3.
On your Vista, click "Start" then "Network". After select the tab "Network and Sharing Center." On the left tab, click on "Manage network connections." You will see a Local Area Connection and a Wireless Internet Connection.
4.
Use your mouse to select both icons and right click. Click on Bridge Connections. Turn on your XBOX 360, Sign In, and you will find yourself connected to XBOX LIVE.
5.
Once you are done, and you need to use your computer for other uses. Simply right click on the Bridge Connection and select disable.
For more information on how to connect and use xbox go to the link below you will find all the details :
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
Oct 31, 2010 | Computers & Internet
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    Not connecting to internet
    I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
    Jun 07, 2010 | Video Game Consoles & Games
    How to hook your xbox360 to laptop to get on xbox live
    wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
    Oct 25, 2009 | Microsoft Xbox 360 Console
    Unable to connect
    You have to set up a network bridge. It's pretty easy to do.
    - Highlight the connection thats online and the ethernet connection then right click and bridge.
    - Wait a few minutes, attempt to get on Live and it should work.
    Feb 09, 2009 | Microsoft Xbox 360 Console
    Xbox live dont work please help
    the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
    a. Direct connection to modem:
    1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
    2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
    4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
    b. Wired connection to router:
    1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
    2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
    c. Wireless connection to router:
    2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
    3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
    4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
    5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
    d. ICS (Internet Connection Sharing):
    1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
    2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
    3. If it's still not working, set the IP Settings manually to be:
    IP Address: 192.168.0.2
    Subnet Mask: 255.255.255.0
    Gateway: 192.168.0.1
    Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
    4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
    If you faced any other kind of troubles with this part failing even after you tried these steps please check me
    Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
    Dial-up 360 to laptop
    plug xbox in via ethernet cable, then open network connections. choose the internet connection and the wired network connection. once both highlighted right click and choose bridge connections. then u might have to change settings on xbox but u may be ok.
    Aug 08, 2008 | Microsoft Xbox 360 Console
    Xbox 360 to wireless laptop
    Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
    Mar 16, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
