1998 Chrysler Town & Country Logo
Anonymous Posted on Sep 15, 2011
I had this issue for my 1998 town and chryler lx1 that when I started the engine it did start but for a 2 to 3 seconds and then came off
Anonymous
Level 3:
  • Master 2,841 Answers
  • Posted on Sep 15, 2011
Anonymous
Master
Level 3:
Answers
2841
Questions
0
Helped
1223452
Points
9607
From your description it appears to be starving for fuel. You need to make sure the fuel pump is running. Listen at the fuel filler door, cap off, while someone else turns on the ignition without starting the engine. If you do not hear the pump run check the fuse, and fuel pump relay. Even if you hear it run that does not mean it is pumping with enough pressure. If you have never replaced the fuel pump on this 13 year old vehicle I would suspect it is bad. Also replace the fuel filter is you have not in the last 50,000 miles.
Would a 2001 Chrysler town and country faulty engine module cause number 2 cylinder not to fire
not likely, since the engine module also fire the plug across from the #2 cylinder on the coil pack. check for spark directly at the coil, if none is found ,then most likely a bad coil pack.
1994 chryler town and country mini van will not start disconect battery cable for a day and it will start work fine shut it off for half an hour it will turn over but won
Code 55 means end of message, Code 12 means controller has been cleared, in other words you disconnected the battery, You are a OBD 1,which means once you turn the key off,you loose the code its votile.You are right about the fuel tank area, As long as you know the symptom you will know the problem,You basically are describing a fuel issue, leaving the vehicle sit for hours with a failing pump will start,when the fuel pump brushes wear out the counter electromotive forces are not there to initiate the pump unless the resistance is low,this is why waiting hours before it start it starts.
3_17_2012_2_39_27_am.jpgAlso get a fuel filter
What is the firing order for a 1996 3.8 chryler town and country van
Firing order is 1-2-3-4-5-6 ; additional details and diagrams for 1998 Chrysler 3.8 liter V-6 VIN "L" could be find in the previous link.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
2answers
I have a99 mercury mountier with anti theft problems some times it won't start with out resting the system through the door lock click 3 times what's up?
are you using a copy of the original key
you need to use the original key for the car
Antitheft and Alarm Systems: Description and Operation
ANTI-THEFT
The passive anti-theft system (PATS) uses radio frequency identification technology
to deter a driveaway theft. Passive means that it does not require any activity from
the user.
The PATS uses a specially encoded ignition key. Each encoded ignition key contains a
permanently installed electronic device called a transponder. Each transponder
contains a unique electronic identification code, with over 72 million billion
combinations.
Each encoded ignition key must be programmed into the vehicle powertrain control
module (PCM) before it can be used to start the engine. There are special diagnostic
procedures that must be carried out if new encoded ignition keys are to be
configured.
The encoded key is larger than a traditional ignition key. The key does not require
batteries and should last the life of the vehicle.
The transceiver module communicates with the encoded ignition key. This module is
located behind the steering column shroud and contains an antenna connected to a
small electronic module. During each vehicle start sequence, the transceiver module
reads the encoded ignition key identification code and sends the data to the PCM.
The control functions are contained in the PCM. This module carries out all of the
PATS functions such as receiving the identification code from the encoded ignition
key and controlling engine enable. The PCM initiates the key interrogation sequence
when the vehicle ignition switch is turned to ON or START.
The PATS function uses the PCM to enable or disable the engine. All elements of PATS
must be functional before the engine is allowed to start. If any of the components
are not working correctly, the vehicle will not start.
PATS uses a visual theft indicator located on top of the instrument panel. This
indicator will prove out for three seconds when the ignition switch is turned to ON
or START under normal operation. If there is a PATS problem, this indicator will
either flash rapidly or glow steadily (for more than three seconds) when the ignition
switch is turned to ON or START. PATS also "flashes" the theft indicator every two
seconds at ignition OFF to act as a visual theft deterrent.
The PATS is not compatible with aftermarket remote start systems, which allow the
vehicle to be started from outside the vehicle. These systems may reduce the vehicle
security level, and also may cause no-start issues. Remote start systems must be
removed before investigation of PATS-related no-start issues.
The PATs key is used on the following Ford family trucks and suvs:
FORD: 1996-2001 MUSTANG, TAURUS
1998-2000 CONTOUR
1998-2001 CROWN VICTORIA
2000-2001 FOCUS
2002 THUNDERBIRD
1997-2001 EXPEDITION
1998-2002 EXPLORER
1999 F-250 LD
1999-2001 F-150, RANGER, WINDSTAR
2000-2001 EXCURSION
2001 ESCAPE
LINCOLN: 1997-1998 MARK VIII
1998-2001 CONTINENTAL, TOWN CAR
2000-2001 LS
1998-2001 NAVIGATOR
2002 BLACKWOOD
MERCURY: 1996-2001 SABLE
1998-2000 MYSTIQUE
1998-2001 GRAND MARQUIS
1999-2001 COUGAR
1998-2002 MOUNTAINEER
Additionally, PATs can be found on the follow Ford family cars and mini-vans:
1998-up Contour
1997-up Crown Victoria
1999-up Escort
2000-up Focus
1996-up Mustang and Taurus
1998-up Windstar
1998-up 2000-up Lincoln LS
1998-up Lincoln Mark VIII, Lincoln Continental and Lincoln Town Car
1997-up Mercury Grand Marquis
1998-up Mercury Mystique
1996-up Mercury Sable
Following are the instructions for programming a blank key (you must have at least one working key for this procedure).
The PAT
1. Make sure you have both keys.
2. Turn on car but don't start. Watch "theft" indicator untils it goes out.
3. Turn off and repeat procedure with second key.
4. After "theft light goes out, insert new key and turn on.
5. Wait until the theft indicator goes off and then turn off switch.
6. Wait thirty seconds. New key is now programmed into security module. Repeat for any other keys.
1. Erase any old codes by entering the factory code.(buttons will light up)
2. Press 1/2 button within 5 seconds.
3. Press 7/8 and 9/0 buttons at the same time within 5 seconds.
To set new code:
1. Enter factory code (numbers will light up)
3. Enter personal 5 digit code(decide beforehand) within 5 seconds of each previous one.
To unlock all the doors,press the 3/4 button within 5 seconds of the driver door unlocking.
To lock all doors and set alarm system,press 7/8 and 9/0 at the same time.
To disarm or reset a triggered alarm,just enter personal or factory code.
Do not set a code with five of the same consecutive numbers. It's too easy for thieves to figure out.
Deactivating and Activating Autolock
To deactivate the "autolock":
With all doors and tailgate closed but NOT locked,and ignition OFF.
1. Enter 5 digit code
2. While holding 7/8 button in, press and release the 3/4 button.
3. Release 7/8 button
The horn will chirp once if the "autolock" was deactivated
or two times if "autolock" was activated.
To reactivate the system,repeat steps 1 thru 3
Alternate Method To Deactivate And Activate Autolock
Do steps [1] through [5] (below) within 30 seconds or you'll have to do it over. If you have to do it over, wait 30 seconds between attempts.
Close all doors securely.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control THREE times.
3.Turn the ignition key from ON to OFF.
4.Press the power door UNLOCK control THREE times.
5.Turn the ignition key back to ON .The doors should lock and unlock.
6.Press the power door UNLOCK control. The horn should chirp ONCE to confirm successful switching of the autolock system
Troubleshooting:
The engine does not start and LED remains off.
1. Check PATS system fuses
2. If alarm is fitted check if LED functions for alarm: if not check cigar lighter fuse (also used for LED)
3. If not go to main dealer
Engine does not start: LED flashes rapidly Leave ignition on until the LED starts to flash a 2 digit code: (sequence- pause-sequence)
Check the following codes:
Code flashes:
1:3 Key code not received. Is key screened by other keys or objects? Try different key: if okay then first key is faulty. If not go to main dealer
1:4 Partial code only received. Try again. If not okay use different key. If not go to main dealer
1:5 Key not programmed into PATS. Program key as above using master
1:6 Faulty link between PATS module and EECV Go to dealer .
Cluster wont light when and wont start 1998 town and country
why my 1998 Chrysler Town & Country started for 2 secs and cut back off now it wont start at all after i put 40$ of gas in the tank
1helpful
Code # PO700
all this code means is that the Transmission computer has asked the engine computer to turn on the check engine light, now u must have the Transmission computer tested to determine the reason the check engine light was turned
2helpful
2answers
2001 Chrysler Town and Country Window problem.
it could possably be the motors for the windows are bad
1helpful
3answers
1998 town & country. It won't start again.
We had the same problem. It was the circuit board in the dash. There were crackes in one of the solder spots. My mechanic removed the dash and did a spot solder on the place with the cracks. It has worked for two months. It seems the solder spot was with a too cool of a solder when it was manufactured. Do it yourself or get your mechanic to fix the probem.
1helpful
Car will not start
Dead or old battery or bad alternator, check voltage, if under 12v, check voltage when car is running to see if the alternator is supplying enough voltage should be 13v+. If not than you might just need a new alternator, instead of a new battery.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
