Question about Home
Jacuzzi ON OUR PANNEL THE PUMP SIGHN IS FLASHING AND SOMETIMES THE BUBBLES ARE NOT COMMING ON TILL THE PUMP SIGHN STOP FLASHING? WHAT IS WRONG ? WHY IS IT NOT WORKING/
  • Rod Kidman
    Rod Kidman May 11, 2010
    is there an error code on the panel when this is happening?
  • Rod Kidman
    We need a bit more information before we can solve this for you.
    Is there an error code in the window when this problem happens?
    What is the control box number?
  • 125 Answers
What control box is under the spa? Get that information, contact the Mfg of the box and they can tell you the solution to the error code in the panel.
Posted on Feb 24, 2009
How do bleed the gear shifting system in mercedesactros4040
if you do not have a bleed valve on the slave cylinder then try removing the cap and pump slowly see if bubbles rise from system if do keep pumping slowly till bubbles stop and cluck is firm.
Jul 12, 2015 | Cars & Trucks
Bleed 2004 musso
Open the bleeder screws at the filter and injector pump ,work the lift pump till no air bubbles at the filter close bleeder screw, keep pumping lift pump till no air bubbles at injector pump close bleeder screw . engine should now start.
Dec 25, 2014 | Cars & Trucks
Everytime I turn on the heating button the bubbles come on how do I fix this
Sounds like you have air pump plugged in the wrong place on the control pack. unplug them all then plug them in one at a time till you find the correct ones. the pump should come on when you press heat and the bubbles when you press air/bubbles. Not a big deal, just have stuff plugged in the wrong receptacles.
Sep 25, 2014 | Pool & Spa
What red light flashing codes
the motor has probably seized from rusted bearings. check pump for problems. possible failure of capacitor for motor.
Jun 22, 2013 | Jacuzzi Home
I have the wires undone the locking ring is off nothing I can see that is holding the motor into the pump housing. Can not get the motor to come out of the Magnum Housing. What am I doing wrong or forgot....
There is nothing else you need to loosen; your pump is simply stuck. It is common for Jacuzzi pumps to be difficult to take apart. You need to keep working the motor side-to-side and up & down till it finally frees from the housing.
John
Jan 29, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a Leisure Bay 24 ft above ground pool thathas a 1.5 hp Jacuzzi Hurricane pump and a jacuzzi sand filter. The pump is moving water very well but I noticed I have "a lot" off bubbles under...
probably a "O" ring as the seal
if the pump is doing what it is supposed to be doing and everything is normal. I would not stress about air under the cover as water contains air in suspension ( how fish get their oxygen to live) and from the turbulent action of the pump impeller , some of that air will be released and collected at the highest point of the flow line
Mar 28, 2017 | Jacuzzi Cyget In Ground Pool Pumps
I see air bubbles in the motor window
Make sure you water level is adequate so as not to draw air through the skimmers. Also, the o-ring on the pump strainer might be bad or debris on it. While the pump is running, shut it off and see if water squirts out of the pump lid or fittings right when it shuts off.
Jun 18, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Jets not working in my ten year old jacuzzi bath
Open pannel and look for a reset button on or near the pump motor.. Or it is posible that the pump motor is shot..
Have a great day !
Nov 11, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
http://hottub.synthasite.com
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Home Logo
109 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
