I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to continue, F2 to run the setup utility
    Sergeant:
  • 300 Answers
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Posted on Sep 16, 2008
Virtual memory
  1. Right-click "My Computer" and choose "Properties"
  2. On the Advanced tab, under Performance, click "Settings".
  3. On the Advanced tab, under Virtual memory, click "Change".
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click "Custom size", and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click "Set".
Virtual Memory should be roughly 1.5 x the size of your installed RAM in case all data stored in Memory has to be written to the hard drive.
Don't forget to click "Set" after you entered the values, just clicking "OK" is not enough!
Just a tip: You can set the VM to "0", reboot your computer and then defragment the hard drive. When that is complete and you allocate the new VM space, it will reserve a continuous space on your drive, which results in better access times.
Let me know if you have any questions!
Jan 06, 2013 | Computers & Internet
Desktop Freezes and lockups..... I've changed out ram, I've tried new hard drive and trying to do a reinstall and it locks up during reinstall.... Opened and cleaned fan and residue underneath fan...
remove power cable, remove ram, remove small battery from motherboard, , paper put in small water, and with it clear ram contacts /only ram contacts/, then put all in teir place, turn on, if it will be lock again, you need chnage power suplay.
Jun 07, 2011 | HP Pavilion a6347c Desktop /Athlon 64 X2...
Want it 2 be main hard drive on desktop,
There seems to be a misconception here. The virtual memory is a part on the Hard drive that your computer uses similar RAM. It only uses it once you have utilized most of your RAM so increasing it would not do much value at all. I suggest you upgrade the physical RAM sticks. (the memory physically attached to the motherboard of your computer). For your Seagate, it would be used just as a storage for data and not as memory. and since it is external, you could also not allocate some part of it to be used as virtual memory.
you could go to a computer store and ask them what memory (RAM stick) would be compatible for your computer if you want to do an upgrade. I'm sure you could also ask them to put it on for you to have the result or your desired amount of memory installed to your computer.
hope this helps.
Jul 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
Jun 21, 2010 | Acer Aspire T135 PC Desktop
I have a deskstop while am put new os for my computer in the drive capacity was just 15 gp in that all the process will completed after the computer will get started there shown the message (there is low...
FIRSTLYThe error shows that your RAM is less i.e. 256 MB not your hard disk. You have a hard disk with capacity of 15 GB but your RAM is 256 MB only. You might be installing either windows Vista or Windows 7 because your system does not meet the minimum system requirements. You need to upgrade your system hardware or you can install windows xp.
SECONDLY You have to install the windows in your desktop only because if you install the windows in your laptop, then all the device drivers will be installed for your laptop only. So it is mandate to install the windows in your desktop only until you are using any third party tool.
Regards
Manjeet
Jun 14, 2010 | Dell (002TR) Motherboard
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel®...
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
Solution.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
How much ram can i install on a hp compaq d220mt?
Laptop Computer Memory Desktop Computer Memory Printer Memory Memory Applications All data processing and execution takes place within the memory module(s). The program's directions are replicated into memory from a hard drive, external drive or from a network. The processor then extracts the directions from the memory and puts it into the circuit for analysis and execution.
Memory is so important that it cannot be wasted. RAM is allocated by the operating system and programs, and then released when not needed. Errant applications can grip RAM and not release it, which results in a diminishing amount of memory available as you load and use more programs.
If you could actually look into memory, you would be astonished. By watching how much and how quick data and commands are written in and out of it each day, you would realize it is a marvel that it works so we
UpgradeComputerMemory.com is here to help you speed up and breathe new life into your computer by adding more RAM memory! We have hundreds of relationships with different manufacturers and carry all major computer memory brands. This includes Dell Memory, HP Memory, Samsung Memory, Micron Memory, Toshiba Memory and many, many more. We can cut through all that computer jargon and provide you with the part that will work each and every time. Our 100% guaranteed compatible RAM memory upgrades are available for more than 21,000 different computers, laptops, servers, printers and other electronic device.
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
408 people viewed this question
David Payne
David Payne
