Question about Lexmark Office Equipment & Supplies
MY PRINTER NEEDS TO BE ACTIVATED - Lexmark Office Equipment & Supplies
I LOS MY CD FOR MY HP DESKJET 5440 PRINTER AND I NEED TO ACTIVATE IT
Posted on Apr 27, 2009
Why cant my windows xp share printer w windows 7?
Hi Chris,
Make sure that both Computers are turned ON if you are printing from Win7 through Win xp
Also make sure that the printer is installed on both machines and that the printer sharing is set up, and that both computers are on the same Workgroup.
Also make sure that the Turn On network discovery is activated in windows7 for XP to be able to detect it on the network, and that the File Printer Sharing is also activated, make sure everything in the sharing settings is activated in the network.
I hope that this will help,
mvincentc
Apr 16, 2012 | Toshiba Computers & Internet
My hp Deskjet F4283 printer keeps printing only half my page. It prints half way and then stops and the paper stops in the printer. How can i fix this?
I unfortunately don't know this printer but in the bigger picture this problem type is generally caused by the exit sensor... usually this sensor is activated by a flag arm in the output bin, find the flag arm and you'll find the sensor... sorry but it's the best I can do...Either the sensor is dirty(use Canned air) bumped out of place(readjust its seated position) or it's dead and needs to be replaced... if this helps, please mark as FixYa!
Jul 27, 2010 | Office Equipment & Supplies
There was a paper jam. I got the paper out but now error message 6A00 appears in the screen. I have tried to turn off and on.
The error code means paper path jam.
Inside your printer a paper path sensor has been activated indicating paper jam so the printer will give off a 6A00 code.
So please check for any stuck paper, debris
The offending item needs to be removed or the purge unit needs replacement.
Also clean the purge unit out make sure all is clean
May 11, 2010 | Canon PIXMA MP610 InkJet Printer
Erro 6A00
The 6A00 is a Canon code for paper path jam. In the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 .
The purge unit is stuck and not able to move freely .Move the purge unit back and forth for around 10 times and then restart printer ,it should work fine .
If you still get the error code then purge unit needs replacement.
Hope this helps .
Mar 27, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printer not activated-error code 30
Sometimes, you may get printer not activated - error code 30 when you try to print using your printer. It may occur when you try to print a PDF document. Sometimes, your Antivirus scripts block you from generating the document and you may have to face this issue. If you have installed Antivirus software and you have encountered "Printer not activated" error, you need to disable script blocking. If this does not resolve the issue or you do not have installed Antivirus, you need to change the Calyx Document Converter printer settings. If it also doesn't work, you need to reinstall the printer driver in your system.
Jul 12, 2009 | Cannon Office Equipment & Supplies
PRINTER CANON/MP150. BECAUSE I HAD TO DO A RECOVERY ON MY COMPUTER, THE PRINTER IS NO LONGER ACTIVATED. OBVIOSELY IT NEEDS TO BE RECONNECTED,PLEASE HELP. VICTOR
You need to install driver for Canon MP150 printer. If you have driver CD came with printer then insert it in DVD ROM to install drivers again
Or Click Canon Support and Select OS (Operating System like Windows XP or Vista) and download mp150vst110bea13.exe file and save it. After download, click that file to installation.
Printer will connected with computer as it was before.
Hit "add a comment" button for further query / info.
Thank you.
Below is an image of Canon Support page with marks on Select OS and Driver file..
Apr 11, 2009 | Office Equipment & Supplies
Problem when printing
Does it say its not activated or off line?
You can simply right click the printer icon and select use printer online
Aug 25, 2008 | Office Equipment & Supplies
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
