Question about RCA P52937 52" Rear Projection Television
RCA P52937SG Will not turn on, only makes clicking sound.
Several weeks ago, my RCA P52937SG big screen started turning itself on and off. I would turn it on, and after about 2 minutes it would turn itself off again, and within 15 seconds, turn itself back on. Again, after about 2 minutes it would turn itself off and continue the cycle.
Then one day it just turned itself off and was not able to turn itself back on. It just makes a clicking sounds over and over again.
I feel confident that I could make the repair if I knew for certain what the problem was. Any ideas?
  • 2 more comments
  • drupert5 Sep 15, 2008
    I have the same problem I looked through the vents on the rear of the TV and I can see a light flickering as its clicking almost like a fuse would like to know if I can fix this myself
  • kevinsegura Sep 18, 2008
    I got this tv from my uncle. When I plug it in all it does is beep and beep. No picture or anything just this beep. None of the buttons will respond
  • Anonymous Feb 04, 2009
    I have the same problem, will not turn on just makes a clicking noise, with a read light flashing in the back round
  • Anonymous Mar 10, 2009
    Same problem it just clicks clicks and clicks.
I had the same problem with mine. There are two voltage capacitors in there. A low and high. The hig voltage is bad. I had to have mine in the shop. Cost about $400
Posted on Sep 16, 2008
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
the part is called the convergence ic. replace those ics.
Mar 22, 2011 | RCA 32F531T 32" TV
My 96 GC 5.2L V8 started acting up a few weeks ago by taking several turns of the key to start. Now the only way it will start is if I add starter fluid to the throttle body and once it starts it runs...
This sounds like a weak fuel pump, put a preasure gauge on the fuel rail and check the preasure with the engine off turn on the key and preasure should be 47psi to 51 psi.lower than 47 replace the pump, a few pounds make a big diffrence when trying to start,
Aug 06, 2010 | 1996 Jeep Grand Cherokee
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
RCA F366550
your hori out put is proably shorted,which means you have no high voltage, also your flyback transformer could bad.
Jan 18, 2008 | RCA F36650 36" TV
Rca p52937sg
Try unpluging it for 15 min.and try it ,if it don't work it might have a leak in your button,it is a simple and cheap repair.I suggest to call your local repair shop.
Dec 23, 2007 | RCA P52937 52" Rear Projection Television
RCA Big Screen is fuzzy.
Common problem and RCA recommends the following to cure: replace R17520 with p/n# 218508, C11503 with p/n# 194903, and crystal.
Bill
Dec 12, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
672 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
